I wrote a clock multiplier/divider that I use all the time:Tropic Al wrote:Anyone got any they can share (that aren't already on the site)???
https://github.com/attejensen/grains/tr ... r/mult_div
Is the arduino oriented correctly? USB jack is up and closer to the jacks, opposite the euro power connector. I asked Jan what the right way was, because it wasn't obvious to me. That's why I'm asking.Mrs_Audio_Boy wrote:After a couple of tests, I found out that my Grains module does in fact work and produces sound correctly, but only when I connect an USB cable to the Arduino, no matter if the Eurorack ribbon cable is attached to the module or not, and no matter what code I upload to the Arduino. On the Arduino, the "PWR" LED glows very dimly, when the ribbon cable is attached. However, when the USB cable is attached to the Arduino, the "PWR" LED glows brightly, as it should do, and the module seems to respong correctly to input signals an knob movement by producing appropriate sounds.
My questions are:I appreciate any help or suggestions.
- Did any of you experience such a behaviour with the Grains?
Is there a circuit diagram available, which might help me to debug the module by trying to track the electricity flow?
Wow, that is excellent, thanks for sharing that. I need a "master" clock module and was thinking how I could build one. Looks like Grains could be the answer, hardware-wise!atte wrote:I wrote a clock multiplier/divider that I use all the time:Tropic Al wrote:Anyone got any they can share (that aren't already on the site)???
Devon Dumpling wrote: Hi there, that sounds very odd. I personally did not experience this behaviour. Have you emailed the info@ginkosynthese.com? You should be able to get help from them. Or did you try Thonk? They are very friendly & helpful! Best of luck anyway!
Hi Jan!
Thank you for your reply, I appreciate it! I checked my Grains V2.5 module again and would like to give you feedback. I attached screenshots which might help visualize the current situation:
- 1) The ribbon cable is plugged in the right direction, i.e. the cable's red stripe is aligned with the "RED" marking on the module (see attachment Powered_from_USB.jpg).
2) All the diodes are soldered in the right direction (see attachment Diodes.jpg). Additionally, both the capacitors C4 and C6 are soldered in the right direction (see attachment Capacitors.jpg. Here, I detached the Arduino in order to better show the capacitors. Although the picture is blurred, one can identify the capacitors' direction, I think).
3) The 78L05 regulator is soldered in the right direction (see attachment Diodes.jpg).
When powered from the modular, the Arduino receives power, but somewhat differently from when it is powered via USB:
- 1) When powered from the modular via the ribbon cable, the only LED that lights up is "POW"; also, this LED is glowing somewhat dimly (see attachment Powered_from_modular.jpg). As I mentioned before, the module doesn't produce any sound.
2) When the USB cable is connected to the Arduino, the "POW" LED is glowing much brighter. Also, the "L" LED flashes eight times and then stays lit constantly (see attachment Powered_from_USB.jpg). As I mentioned before, the module produces sound as intended.
Could you give me some further hints, what I could check next?
Also, thank you very much for your help! The orientation of the Arduino is correct, as you may see in the attached images. I didn't use my voltmeter to check the voltages yet, but I surely will do that. Just a couple more questions on how to go about it, since my knowledge about electronics is somewhat limited:NiteEagle wrote: Is the arduino oriented correctly? USB jack is up and closer to the jacks, opposite the euro power connector. I asked Jan what the right way was, because it wasn't obvious to me. That's why I'm asking.
I did some voltage readings on mine.
On the Arduino board.
VCC pin = 12V
5V pin = 5V
3.3V pn = 3.45V
On the voltage regulator on the main board.
Pin closest to the jacks 5V
Pin closest to the Arduino 12V
I hope this helps with some basic troubleshooting.
I checked the voltages on mine.
Can you explain what each pot does and what each in/out is used for in your firmware? Thanks, interested in trying it out.atte wrote:I wrote a clock multiplier/divider that I use all the time:Tropic Al wrote:Anyone got any they can share (that aren't already on the site)???
VCC pin = 12V
5V pin = 5V
3.3V pn = 3.45V
Devon Dumpling wrote:I saw the video with the Cereals code which I thought sounded great, so installed that instead. And the results were pretty good, quite similar to the video!
However… with Cereals installed, when I turn the pitch (knob 3) beyond about 1 o’clock, the sound just suddenly cuts off (apart from what sounds like static crackles), which doesn’t happen in the video - at the very end (about 55s) knob 3 is turned right the way up and back down, and it seems OK. This happens wherever my other two knobs are.
So has anyone else had this problem? What could it be, apart from shoddy soldering work? I’m doubting my ability to build any more expensive kits at the moment! I’m thinking of re-soldering pot 3 (if I can get the knobs off).
The same happened to me, after 1 o'clock it cuts off.hautlle wrote:I get this same behavior with my Grains at various times. I've loaded my own samples into the Cereals code and the sound will cutoff at random points, usually when trying to go to very high pitches/short grains.
I've wondered if this is a shortcoming in the code/processing ability or if there is something wrong with my build? I've not seen the video you are referring to.
Anyone else that can chime in?
I have the same result, didn't know it was an issue as the input for that pitch is coming from a Doepfer A-156 so didn't notice.jschussler wrote:I'm dealing with the "jack 3" issue (Grains only produces frequencies above 3K unless you plug a cable into jack 3).
Does anybody have the latest info on how one might fix this? Reading the thread, I see several mentions of adding a resistor, but it's not clear to me that doing so fixes this particular issue, and exactly where the resistor goes.
Help?
It could be possible that the grains in the video is the v1 or a version that differs from the version you have. The knobs and jacks are in the same place on all versions so it could be a newer panel but a v1 board.Devon Dumpling wrote:Comparing the video with mine, what seems to be happening is the "range" of pot 3 on my module is "compressed" up to the one o'clock position. So the highest frequency from the module on the vid is fully clockwise, but on mine it is at 1 o'clock, after which there is nothing. It's like the pot is allowing too much voltage through, if that is possible.Devon Dumpling wrote:
Anyone got any idea?
Mostin77 wrote:1)mine wasn’t programmed. I was also confused by wether it was programmed or not.glennfin wrote:1) how do I know if the arduino has been programmed?
2) If the arduino needs to be programmed, can it be done with a simple usb cable from a windows PC?
2)yep, should work fine.
