Dang. That sounds awesome. I guess you got one of the prototypes right?wellurban wrote:Ooh, I have to try this :-)SunSpots wrote:What else would be cool is
Clock 1 to sequencer
Sequencer running bass voice
Do not plug the sequencer gate out to your bass voice
Clock 1 to branches
Probability down
Probability gate out to bass voice
So the sequencer is always running, but the actual firing of the gate to trigger the voice is set to probability. Triggering voice is always on time, but which of the 8 notes will it play?
My Branches arrived just last week, and I've only just started playing with it, but I ended up with a lovely patch last night. Set the two outs from one half to the clock inputs of two sequencers, each of which drives its own osc. If they're both set to compatible scales/chords, the result is two interweaving melodies, sometimes one running ahead of the other, then retreating, for subtle evolutions. Drive the probability with a slow LFO or envelope and, and you get gradual shifts between drones and busy riffs.
A great little module!
Mutable Instruments Branches
- SunSpots
WTB: VULT Freak. MPC X good condition, rabid elephants natural gate, Instruo Arhbar, Make Noise Shared System B/G plus
- Kent
- Curator/Janitor/Zookeeper
This reminds me a bit of the functionality of the "tock" output on the Eardrill Pendulum/Ratchet. However, on the "Branches" one always has the 'dropped' Gate/Trigger available on one bus or the other. If I were still in Euro, I'd grab one of these as it is an fantastic solution for providing correlated yet filtered (dropped) pulses.
Yes: it was a surprise addition to a large order, and a very welcome one :-)SunSpots wrote:Dang. That sounds awesome. I guess you got one of the prototypes right?
It also works way up into audio rates, for various CV-able flavours of digital noise. And if one half is jumpered into flip-flop mode, it'll be a sub-octave divider at one extreme of p, unison at the other, with unique forms of chaos in between. And I've only just scratched the surface so far. A really useful little module!
- infradead
- leader of the secret trombones
color me interested as well
Tacoma Noise Rodeo
Tacoma Noise Rodeo
- lessavyfav
- Ultra Wiggler
Is this come up already? I didn't see it- Is 12:00 50% random chance? I assume but would love if at exactly 12:00 it would work like a flip flop - a-b-a-b etc. Then the module could pull double duty as a flip-flop/ divider as well as coin tosser. Anything outside of 12 would work as planned.
Though as I type I wonder if the non-random 50% could also be interesting at different ratios... 9:00 would would be 75%:25%(/4) so you'd get an output like: a-a-a-b-a-a-b... And so on. Would this make cool divider like patterns? How would "weird" ratios respond? How would that sound at audio rate? Jumper mode? Who am I to start spitballing half baked ideas?
I'm Tim and I'm excited for modular synthesis!
- SunSpots
The short answer is we need this module so we can play with it.lessavyfav wrote:Is this come up already? I didn't see it- Is 12:00 50% random chance? I assume but would love if at exactly 12:00 it would work like a flip flop - a-b-a-b etc. Then the module could pull double duty as a flip-flop/ divider as well as coin tosser. Anything outside of 12 would work as planned.
- oscillateur
It probably doesn't work like that. In your example you assume that consecutive outputs are correlated but they're not. Each time a trigger arrives, the output is chosen independently of what happened before.lessavyfav wrote:Is this come up already? I didn't see it- Is 12:00 50% random chance? I assume but would love if at exactly 12:00 it would work like a flip flop - a-b-a-b etc. Then the module could pull double duty as a flip-flop/ divider as well as coin tosser. Anything outside of 12 would work as planned.
Still, looks like a great little module, I'd probably be interested in one too (but not in the short term though, only when I'll move to a 6U case).
- ben_hex
- Paranormal Patroler
- joshuagoran
- TheEngineer
I've been putting some together recently. Soon!ben_hex wrote:Quick video? Audio demo?wellurban wrote:
So there's a tiny machine in their that literally flips a coin? Is this a quarter? A nickel?
___________________________
Jupiter Rising
YouTube Performances: https://tinyurl.com/y3ory34z
Soundcloud: https://soundcloud.com/exmd/
Jupiter Rising
I like this, but how about extending this idea even more as an alternate SW for this module or just as another module that would use the same HW:lessavyfav wrote:Is this come up already? I didn't see it- Is 12:00 50% random chance? I assume but would love if at exactly 12:00 it would work like a flip flop - a-b-a-b etc. Then the module could pull double duty as a flip-flop/ divider as well as coin tosser. Anything outside of 12 would work as planned.
Instead of randomly picking one output or the other to output to, how about doing it as a pattern that has 8 steps.
Given 8 bits, there can only be 256 states. I would think 256 states should be doable for a Knob/CV input.
At each extreme of the Knob/CV one or the other output would still get all 8 triggers.
In between you could switch between the two outputs using all 256 8 step patterns arranged like thus:
All the 8 step sequence combinations of 1 of 8 triggers to output A, and 7 of 8 output B.
All the 8 step sequence combinations of 2 of 8 triggers to output A, and 6 of 8 output B.
All the 8 step sequence combinations of 3 of 8 triggers to output A, and 5 of 8 output B.
All the 8 step sequence combinations of 4 of 8 triggers to output A, and 4 of 8 output B.
All the 8 step sequence combinations of 5 of 8 triggers to output A, and 3 of 8 output B.
All the 8 step sequence combinations of 6 of 8 triggers to output A, and 2 of 8 output B.
All the 8 step sequence combinations of 7 of 8 triggers to output A, and 1 of 8 output B.
Some example states where X is on and O is off:
A:
XOOOOOOO
B:
OXXXXXXX
A:
OXOXOXOX
B:
XOXOXOXO
A:
OOOXXXXX
B:
XXXOOOOO
A:
OOXOOXXO
B:
XXOXXOOX
Of course one can do this with an 8 step gate sequencer and a switch now, but you can't switch between all 256 possible 8 step sequences via CV.
https://soundcloud.com/r-nuuja
http://www.facebook.com/are.nuuja
http://rnuuja.tumblr.com/
vqlk: "...so seriously - this a forum dedicated to discussing each other's really lame and un-extreme modular synths??!"
Many of the MI stuff seems like it will remain in kinda boutique domain. I'm affraid they can't keep up with the huge demand. But that's just my thought. However, I really love almost all their stuff and hope for a day, when my desired MI module will be on stock and at the same time I'll have money to order it :]
You obviously don't know what you're talking about. MI stuff get produced at a steady pace and are available periodically as most modules are (re: Intellijel, Makenoise and others). Olivier is expanding his line of production and at the same time looking into new manufacturing prospects to provide a quicker supply. I understand you're expressing your personal thought on the subject but it's an uneducated one and one that can cause a raucous (and has caused a raucous in the past) with no good cause.EGA wrote:Many of the MI stuff seems like it will remain in kinda boutique domain. I'm affraid they can't keep up with the huge demand. But that's just my thought.
Modules become available when they become available. Please refrain from expressing assumptions that can make fellow members panic.
Those initial small runs are essentially betas, sent out in an initial small batch for feedback purposes. Then the bigger run gets made. Other companies do this as well, but it's usually closed to a few select people.
I think it's great that Olivier opens this small run up for other to have a chance to have input to this stage of module development.
Once the main run starts, there are plenty to go around. Braids is on what, it's 3rd major run now?
FT/S US only: MPD224, Traktor S2
- tsunamisucks
- Veteran Wiggler
Re: Mutable Instruments Branches
So I'll keep on waitingpichenettes on the MI website wrote:Received a batch of pre-production Branches. Gross assembly mistake, sent back to the assembly house for repair
