As the name says, it has two Bernoulli gates. What do they do? Upon receiving a trigger/gate (on the IN input), a virtual coin is tossed. Depending on the outcome, the trigger/gate is sent to OUT A or OUT B. The fun is that you can bias the coin with the potentiometer (or a CV). Fully counter-clockwise and it'll always be routed to A; fully clockwise and it'll always be routed to B; and everything in-between.
There is a slightly more complex alternative behaviour in which the coin toss decides between between the "stay on the same output as previously" and "switch to the other output". Fully counter-clockwise and it stays stuck on the same output, fully clockwise and it moves back and forth between the two outputs like a 1/2 divider. At the moment the choice is set by a jumper on the back.
Not sure if I have this mass-produced (price would be in the $90-100/ 90-100€ range). I have 7 boards left that I might finish building and sell later.
One jumper per channel - by default channel 1 has the first behaviour (decide on an which output), channel 2 has the second behaviour (decide whether we change or stay the same).
weell, as i've already pointed out over at the mi forums, i have to confess that this one is actually the first mi module that i don't quite see the point of.
apart from that “stay on the same output as previously†mode, what does this do that you couldn't easily achieve with some of the most basic utility modules everybody already has in their systems, like:
noise source (a118) + s&h (a148) + offset/attenuverter/polarizer (a183-2, cv tools, shades) + vc switch (a150) + maybe a vca?
is it really worth investing 90 euros and 6hp?
or maybe i'm missing something and just don't understand this module's functionality?
I used to patch something similar up by running a vco at a high frequency into the data input of a flip flop (or s&h). The pulsewidth control becomes the probability control.
Actually, this is rather the sort of module i actually need and thought of how to achieve with as few modules/investment as possible. This one nails it.
Please, tell me where to wire the money if you make some more.
bartleby wrote:weell, as i've already pointed out over at the mi forums, i have to confess that this one is actually the first mi module that i don't quite see the point of.
The basic function can be achieved by other means, but maybe the immediacy of having the function x2 ready to roll in a compact form is quite appealing. The extra trick it has is also a good one.
gde wrote:I used to patch something similar up by running a vco at a high frequency into the data input of a flip flop (or s&h). The pulsewidth control becomes the probability control.
I've found with this patch the VCO frequency needs to be modulated if the output is being sampled by a regular clock. Otherwise you hear a pattern due to fixed relationship of the VCO and clock
microfauna wrote:maybe the immediacy of having the function x2 ready to roll in a compact form is quite appealing.
it appears to be to some. not to me though. i don't think i would need this kind of probabilistic gate often enough to justify a dedicated module. when i do want one, it think i'll just patch it up with what i've got anyway.
so, each to his or her own, i guess...
The same argument would rule out sequencers too - they could be achieved with A-161s, A-138s and switches.
The point is to have a higher level building block for probabilistic/generative patching - that can be taken alongside a sequencer or trigger generator, without taking too much space, to add a flavor of randomness to it.
pichenettes wrote:The same argument would rule out sequencers too - they could be achieved with A-161s, A-138s and switches.
true. i actually did that for quite a while until i got my first dedicated sequencer module...
i think i do use a sequencer more frequently than a probabilistic gate, though.
anyway, i guess it's just not for everyone. some - like myself - prefer to patch up more complex functions from a few, very basic modules, others prefer more integrated complex modules...
I hate to be that guy, but, I would love to see these small utilities you've got going in 4HP, particularly the Shades
The knobs don't need tweaking with all the time and even so it's still perfectly comfortable on something like the ma Mix
This is exactly why I would buy one if you're selling them and probably never sell it. I'd put it right next to my trigger riot and grids.
WTB: VULT Freak. MPC X good condition, rabid elephants natural gate, Instruo Arhbar, Make Noise Shared System B/G plus
