audio damage grainshift in use
- Paranormal Patroler
- DonKartofflo
- The knob-twisting Hive Mind
- ignatius
the pitch input is a CV input. it's for modulation of the pitch parameter. so it expects a CV input w/in a certain range.. as most if not all CV inputs do.DonKartofflo wrote:does the pitch input track 1v/oct?
per radiokoala in the other thread
viewtopic.php?t=93028&start=230
V/oct = 1v spans one octave. On Grainshift effective range is 4 octaves (2 up, 2 down) when using the CV input, and it will respond to -5V/+5V signals. 10V/4oct = surely not. You could say it's 2.5v/oct
- nearly ghost
- Veteran Wiggler
- DonKartofflo
alright thanks for the detailed explanationignatius wrote:the pitch input is a CV input. it's for modulation of the pitch parameter. so it expects a CV input w/in a certain range.. as most if not all CV inputs do.DonKartofflo wrote:does the pitch input track 1v/oct?
WTB (EU): Mungo d0, c1Nelson Baboon wrote:Beware of people who tell you to smile.
Just got my grainshift, and ive gotten some really cool textures out of it so far. Is there an easy way to make it stay at one octave up? If I put the pitch knob all the way up, it goes past the octave. I tried putting in a dc offset from my 8nu8r, but it still seemed a little challenging to get it to lock there.
I understand there will be some slight pitch variation as part of the effect, but I just mean on average. Apologies if this was already explained.
Yes, there was a long discussion on the original announcement thread about the knobs, these are identical to The Harvestman knobs.Knights Who Say Neve wrote:The knobs on my grainshifter are wobbly as fuck. Are anyone else's?
I'm ignoring the fact they are wobbly and just trying to get to grips how to use this grain shift module on drums.
They may feel a bit wiggly, but they're tough as nails. In 400 modules (which is 1200 pots) we had one single mechanical failure of one pot, which is a pretty good rate. (And that failure was after I sent the module back to the assembly house for a repair on that very component, so I can't say for certain where and when the failure occurred.) I've put a module through a dishwasher cycle, and been very hard on them in general, and they hold up fine.
For what it's worth, I was a professional performing musician for a decade and a half, and am in no way easy on equipment. The only factor I really consider in any particular piece of gear's usefulness is whether it will stand up on stage. (For those that follow me on Twitter, you may remember my long series of Tweets about the stupidity of having floor effects with iPad docks, for example.)
As I said in the other thread, I'm not happy with the pots, but in candor, my unhappiness is largely because I know you guys will bitch about it, and I'll have to talk about it all the time, not because of any lack of confidence in the product itself. But lesson learned, and we're looking for a different solution for future products.
But the Audio Damage brand is now, and has always been, about standing behind our products. If one of the pots (or jacks, or whatever) fails, just send us the module and we'll replace the entire unit, no questions asked, and pay the shipping.
Chris Randall
Audio Damage, Inc.
Web: http://www.audiodamage.com
AI Vlog: https://www.youtube.com/channel/UCxo8sM ... xUVkj0krdw
Audio Damage, Inc.
i didn´t liked the pots on my harvestman polivoks VCf,
the Freq knob was grinding on the faceplate which was not good for jamming.
the grainshift has small knobs, i have here no problems with the wobblyness of the knobs.
the grainshift is very "jammy", the spacing is whats working against it.
i would consider immediatly a second unit....now i better wait and see if there´s an update happing on later modules.
personally i think, its the good modules where unperfectness hurts.
......bad modules can go. .....grainshift will stay. like it very much
For sale:
We were told by pretty much everyone we asked before starting this (and, I'll note, during our previous ill-fated foray in to Euro as well) that the three main things to consider were module depth, HP, and cost. So the goal was a DSP-based module with three knobs + CV control on a single horizontal board in the minimum width possible, for the lowest possible cost. That's where the ADM0X modules ended up.Funky40 wrote:the grainshift is very "jammy", the spacing is whats working against it. i would consider immediatly a second unit....now i better wait and see if there´s an update happing on later modules.
The ADM1X modules will be stacked boards with dedicated panels, and cost and size will not be considered as primary factors. The main considerations will be the highest quality panel parts and usability. There will be a granular module in this line as well, with far more capabilities (the larger platform has much more RAM, so we can do stereo granular engines and stereo delays with 3-5 seconds of delay time at 48/24 simultaneously.) However, it isn't our focus for the first couple of the larger platform; it could be a year or more before we have it done and on sale.
Chris Randall
Audio Damage, Inc.
Audio Damage, Inc.
They are more than a bit wiggly. There are far and away the most wiggly of anything in my rig (which has all the usual suspects, i.e. Make Noise, Harvestman, Intellijel, Doepfer, 4ms, Livewire, Tiptop), or of any of my other gear for that matter. There's no anchor to the panel - the pot shaft just sticks through - and with the knob removed you can see how much wider the panel hole is relative to the shaft size. I honestly thought that might be a manufacturing error on my unit.Crandall1 wrote:They may feel a bit wiggly, but they're tough as nails. In 400 modules (which is 1200 pots) we had one single mechanical failure of one pot, which is a pretty good rate. (And that failure was after I sent the module back to the assembly house for a repair on that very component, so I can't say for certain where and when the failure occurred.) I've put a module through a dishwasher cycle, and been very hard on them in general, and they hold up fine.
Speaking of holes and spacing...
Apologies in advance if anyone takes offense, but the panel design with those giant "graphics" is decisively not my cup of tea. So, the layout of the module looks pretty symmetrical, and i am wondering if just flipping the panel would work. Did anyone try that. are the holes for jacks and knobs the same size, and spaced evenly on both sides?
i think i would rather have a totally blank panel than the one adorned with pictures... :-)
EDIT: Tried it: panelas are not symmetrical. Plus the holes for jacks and knobs are different size, so flipping the panel does not work as a "simple fix" for me.
archive / / / http://www.laborcamp.org
instagram / / / https://instagram.com/laborcamp
facebook / / / https://www.facebook.com/labor.camp
sound cloud / / / https://soundcloud.com/labor-camp-orchestra
- ignatius
i shredded some sounds from the cyclebox the other day. grainshift is fun for this kind of thing.. i'll be using it a lot in various ways.
http://ignatiusmusic.com/graintwists.wav
changed a bit.
now, aesthetically somewhere between gieskes and mungo:
i could not help myself.
Curious to hear if anyone else thought the Grainshift was a bit on a noisy side? As in noise floor.
Actually both of my AD units (Grainshift and Dub Jr) seem to have a bit of a hiss going on...
- EarlJemmings
any chance of changing the pots to something that is bolted to the frontpanel? wobbly knobs are a major turn-off for me ... but the sounds are nice so i'm willing to do some work if possible ...L.C.O. wrote:changed a bit.
You would need to desolder the existing ones. But i don't think it's worth the trouble. I don't find the knobs to be that wobbly. It could also be that i drilled the holes slightly smaller than the original panels.felixer wrote:any chance of changing the pots to something that is bolted to the frontpanel? wobbly knobs are a major turn-off for me ... but the sounds are nice so i'm willing to do some work if possible ...L.C.O. wrote:changed a bit.
But am not sure if that matters.
