WMD Sequential Switch Matrix
ehm.. im not 100% clear about this question, are you able to select stage/step via cv? meaning.. can you go through all the 16 steps in a non linear fashion?
"CV Limit: When the LED is off, CV acts as an offset that can go beyond the Top. When the LED is Green (tap “CV Limitâ€ÂÂ), the CV is limited to the top, so the CV will be clipped to the Top Matrix.
CV Sets Top: Indicated by the LED being red. The CV will set the top matrix. This allows for CV control of the Top matrix, or CV control over the length of the sequence. CV will no longer change matrices in this mode.
Step Down: When the LED is off, gates and the Step button will step up. When the LED is green, gates and the Step button will step down.
CV Input: The CV input is attenuated by the CV Scale knob, and added to the CV Offset control."
- psyclone001
- revoltcrews
- revoltcrews
matrix mutations video..... :)
Getting to know you ...
thats what's happening here with the SSM.
other modules installed today and focused on, and getting abused from the SSM via dual rene feeds, wogglebug, propagate.
hex inverter mutant bass drum
tta 909hats
basimilus iteritas
and echophon.
tta 909hats
basimilus iteritas
and echophon.
Cool, definitely sounds like the SSM I know.
LP released April 2022 - Screen Phoenix - 2.maw-CALT
Soundcloud // Eurorack module demos // MarsMelons - label // Video art
- revoltcrews
- revoltcrews
Hirsbro wrote:after reading the manual and this thread I still don't get what the comparator input are used for![]()
The comparator outputs will produce a gate signal if the voltage at each columns output is greater than the voltage at the comparator input.
Lets just focus on one input and 1st columns comparator output (1>comp)
Try this:
Send a slow attack, slow decay cycling envelope or positive voltage only LFO to input 1 and activate button 1:1. Disable all other matrix routing buttons.
Now look at the two LED's above the 1>Comp jack. The left LED reflects the voltage of the first column of outputs.
Since you are only sending one envelope to the first input, the left LED should reflect the shape of your envelope (less voltage, less brightness). The comparator outputs status is reflected by the right LED. You will notice that when the envelope produces a voltage greater than zero, the comparator output LED turns on. When the comparator output LED is on, there is a gate signal present at the 1>comp jack.
This is because the job of the comparator is to produce a gate signal when column 1 voltage is greater than the voltage at the comparator input. Since there is nothing plugged into the comparator input, there will be a gate produced at the 1>comp output whenever column 1s voltage is greater than zero.
Now send an offset voltage to the Compare In. If you are sending a 3 volt offset to the compare input, and your envelope is going from 0-10 volts, the 1>comp output wont produce a gate until the envelope is greater than 3 volts, and it won't stop producing that gate until it falls back below 3 volts.
This works for the other three columns too. They all look to the compare input, and depending on the sum of each columns voltage, if it is greater than the voltage going to the compare input, a gate will be produced at each columns comparator output.
Use them to clock sequencers, trigger envelopes, etc. I use them at audio rate sometimes for cool effects as well.
Sorry if that was over explainy. Hopefully that helps though.
- revoltcrews
Fantastic example ddoyen
I clearly understand the comp now. thanks so much.
And here's my 3rd noise date with the SSM. exploring cv'ing the matrix with maths eoc & jupiter storms osc outs....
all sounds are being driven by the ssm's outputs, and a couple of the comp outs are triggering mutant bass drum and basimilus iteritas
and by noise session. i mean its quite noisy. i like dates like this:
- thingstocome
- Happyanimal
- Veteran Wiggler
Does it require 5v? cant find that info not even on http://www.wmdevices.com/ssm.ph
I am planning a power supply change around
As in a 5v adapter? Nope.Hirsbro wrote:Does it require 5v? cant find that info not even on http://www.wmdevices.com/ssm.ph
Pretty much everything goes through the SSM in this patch. Just sayin'.
It's a great module, super handy for making variations in patches.
http://soundcloud.com/happyleaguecactus ... en-dum-ide
