OCD question about gaps between modules.
Headlands
Post by Headlands »
I'm putting my rack together today and my OCD is on overdrive because of slight gaps between certain modules, no matter how I adjust them with the leeway in most modules' screw holes (some have no leeway -- should be some in every module design!). If this is simply something one must accept with modular then I'll be totally OK with it. Would just like to know if that's the way it is sometimes. ;)
Kawouddd
Re: OCD question about gaps between modules.
Post by Kawouddd »
One of the reasons I hate mutable *shakes fist*
SkyWriter
Post by SkyWriter »
I use sliding nuts and a feeler gauge :0)
OH YOU NEED LITTLE TEENY EYES FOR READING LITTLE TEENY PRINT
LIKE YOU NEED LITTLE TEENY LICENSE PLATES FOR BEES.
Agawell
Post by Agawell »
the tiny gaps are good as they will allow a little bit of air flow...
Headlands
Post by Headlands »
OK, good -- as long as I know it's something that's not "wrong" then I'm fine. :-) Thank you.
And every single module maker and faceplate-maker should always have some leeway with their screw holes; there's not a single reason not to! So far with what I have, Joranalogue, Doepfer and Make Noise are guilty.
Misk
Post by Misk »
gaps between modules, huh? Ever noticed how faceplate thickness varies between manufacturers? welcome to my personal hell :P
Wavtekt
Post by Wavtekt »
who cares ...
gaps / different panel thickness / different shades of silver & black panels / different screw hole sizes ... thats the nature of eurorack.
Get a single manufacturer system or go Buchla / 4u / 5u if thats matter for you.
dooj88
Post by dooj88 »
starthief
Post by starthief »
Even single-manufacturer systems aren't necessarily immune to gaps, due to poor quality control on their panel cutting, inconsistent placement of screw holes, etc.
I agree though that it'd be nice if screw holes always were at least a little bit oblong. Somebody mentioned Mutable, but at least those seem to be 100% dead-on. The Harvestman mk2 are the ones I've had the most trouble with alignment, and Doepfer the worst for panel cutting generally.
Headlands
Post by Headlands »
Wavtekt wrote: Fri Jan 14, 2022 4:26 pm who cares ...
It's got nothing to do with what's actually important or what actually matters -- it's an OCD thing. Luckily I only have OCD for a few things in life, but gear/things I buy is one of them. I'm fine now that I know it's just the way it is with Eurorack. :-)
Spacelordmother
Post by Spacelordmother »
SkyWriter wrote: Fri Jan 14, 2022 1:44 pm I use sliding nuts and a feeler gauge :0)
Yup! This is the way. :tu:
kriskeyman
Post by kriskeyman »
Have been using sliding nuts with the same bent paperclip for years to move the nuts in the rack. No module is missing a screw in one of the corners and the gap between modules is pretty close
Wavtekt
Post by Wavtekt »
Headlands wrote: Fri Jan 14, 2022 4:57 pm
I guess seeing channel 1 of Maths shoots out 9.81v envelope and channel 4 shoots out 9.90v envelope will get you really mad?
This is the nature of the analog world we live in and why there is tolerance to the manufacturing process.
resistors have 1-2% tolerance, VCO is never exactly 10vpp, usually +/- 0.5v , drill bits wears off from time to time so size changes, wood beams doesn't size all the same with all sorts of defects like cupping, your left face is asymmetrical to your right face etc.
May be you sure either get help or go to digital world where everything is precise.
Headlands
Post by Headlands »
Wavtekt wrote: Fri Jan 14, 2022 8:13 pm
I think we might have a communication misstep here. I was just asking a simple question about module spacing in order to hopefully squelch my OCD with this kind of thing, which it did.
ATW
Post by ATW »
Wavetekt—please be careful with the dismissive attitude. “Who cares?” and “ May be you sure either get help or go to digital world where everything is precise” is not particularly constructive.
I assume the intent was to be helpful. Please give others the space to communicate freely—particularly in the realm of mental health.
Thanks.
ᴍᴏᴅᴜʟᴀʀ ɢʀɪᴅ ⟡ 9U 168 + Palette + Pod ⟡ ᴍᴜsɪᴄ ATW on SoundCloud
In actual fact -and a boon if you are *truly* ODC- there *should* always be some *varying* gaps between *all* modules. It actually should be a tossup whether two modules sides meet or not.
Here's why.
The spec for 3U Panels -that Doepfer *adopted* for Eurorack- includes a tolerance for every module's width. This ius because it's impossible to actually cut every single panel blank to exact size. So in all areas of mfg, things like this are given a tolerance.
Since rack widths AKA sub-racks- generally -again existing *well* before Eurorack and Doepfer's adoption of this part of that pre-existing standard- have fixed mounting hole positions, the worst situation is panels which are too wide. Therefore the tolerance is plus 0, minus some typical amount. On full racks this is plus zero, minus 0.030" or 0.8mm. You can read the exact numbers for typical Euro panels on Doepfer's website in the mechanical section.
So fear not !those of you with ODC.. Your OCD is actually satisfied by having variable gaps. Because that's the expected and planned result from beginning by the powers who first made the decision to package electronics in this way!
And as someone earlier pointed out it's actually a help to cooling what is too often otherwise a sealed box. Unused Jack holes used to help much in this regard, but the rise of PCB mounted jacks -without a thru hole under the jack- have mostly eliminated this formerly helpful aid to heat removal.
Headlands
Post by Headlands »
KSS wrote: Fri Jan 14, 2022 9:23 pm In actual fact -and a boon if you are *truly* ODC- there *should* always be some *varying* gaps between *all* modules. It actually should be a tossup whether two modules sides meet or not.
Here's why.
Perfect! This sealed the deal. Thank you.
jsleeio
Post by jsleeio »
clearly none of you are truly CDO, you can't even get the letters in the correct order!
good point on the jacks not providing an airflow vector anymore. This does also mean they are less of a dust vector, though...
Zap him again! ZAP THE SONOFABITCH AGAIN!
sket
Post by sket »
what does the feeler gauge do in this case?
jsleeio
Post by jsleeio »
sket wrote: Fri Jan 14, 2022 9:49 pm
it would ensure even gaps
tdallas
Post by tdallas »
Some air flow supporting gaps are fine (to me). My magic brain fart sometimes goes „brrrrr“ when knobs on a newer module begin to wobble or loosing their „haptic resistance“ … the beauty of hardware :hihi: :hit:
I really envy the people who can throw modules in a rack without much concern and just make music.
SkyWriter
Post by SkyWriter »
jsleeio wrote: Sat Jan 15, 2022 2:30 am
yes. feeler gauge is used to gap spark plug(s) - and other stuff.
I am intolerant of tolerances! lol
R.U.Nuts
Post by R.U.Nuts »
Headlands wrote: Fri Jan 14, 2022 2:20 pm
It's easier and hence cheaper to drill simple round holes. So production cost is a reason. Sliding nuts FTW.
Pelsea
Post by Pelsea »
Tip: don’t tighten any screws until all of the panels in a row are in place. This lets you slide things around if the last couple of panels are tight.
Books and tutorials on modular synthesis at http://peterelsea.com
Patch responsibly.
pqe
jsleeio
Post by jsleeio »
Pelsea wrote: Sat Jan 15, 2022 12:52 pm Tip: don’t tighten any screws until all of the panels in a row are in place
this is good advice ... until you have really long rails.
I've found with my Doepfer Monster cases (168hp wide) that populating them is much, much easier if I temporarily install a pair of 4hp panels on either side of the middle of each row and tighten the screws down properly. Keeps the rails closer to straight and parallel. Especially in the Monster Base where access to the top rail in the top row is a bit diffcult
