Buchla 200 in Euro format (Tiptop)
dgrainger
Re: Buchla 200 in Euro format (Tiptop)
Post by dgrainger »
Aw, 266t has been pushed back to December, according to tiptop's buchla page.
bhmcc
Post by bhmcc »
:despair:
exper
Post by exper »
dgrainger wrote: Wed Nov 09, 2022 6:57 am Aw, 266t has been pushed back to December, according to tiptop's buchla page.
Bummer. I was hoping it was going to be out imminently.
FT US: Akai Force + MPD226 for Maschine +
The Junglechrist
Post by The Junglechrist »
Hey there euro Buchla folks! I prepared a video about all my favorite tricks with the 257t and 245t that I've seen in recent Todd Barton's videos (or from others).
Feel free to come say hi or ask any questions during the premiere tomorow at 18:30 French time ;-)
adnauseam
Post by adnauseam »
I've been using a couple of 257t modules in a new rack configuration.
My most frustrating observations are:
  • There's no attenuator for the crossfade cv input
  • Voffset is only 0-10 and no option of -5/+5,
  • and lastly: I do not at all understand the point of the +5V offset switch for the middle section. The graphic seems to imply this (5V? or is it 4V? What is .5?!?) appears at Vb. I'm not really sure of the utility of this. Does it mean that at 12 o'clock, (50% Vb / 50% Vc) a signal incoming at Vc is offset by 0.5 (4V?)
Are there any tricks, other than using both channels, or utilizing the first section, to get negative offsets? :help:
Using the 257t with Ornament and Crime has proven difficult as inputs are expecting -3V to +6V. I know this is where having a susinct and coordinating engineering philosophy helps. The TT Buchla modules all work very well together.. *Grumble* something someting standards *Grumble*.
--I'll stop myself here from getting into a rant about problems with Euro pairings and instead bite my tongue. :doh:
feelingthin
Post by feelingthin »
Does anyone know what the expected cv value is for the crossfader cv on the 257t? It's not listed in the manual. Is is -5v/5v or -10v/10v?
adnauseam
Post by adnauseam »
feelingthin wrote: Tue Nov 15, 2022 6:43 pm Does anyone know what the expected cv value is for the crossfader cv on the 257t? It's not listed in the manual. Is is -5v/5v or -10v/10v?
Or -8V/8V??!
feelingthin
adnauseam wrote: Tue Nov 15, 2022 9:22 pm
Or -8V/8V??!
Or 0v. I would make modules with useless inputs just to throw people off. In all seriousness, it's probably -5/5v I just want to check.
Spanningtree
Loop free patching via 802.1d
Post by Spanningtree »
It appears to be 0 to 9 or 10v. I tried negative as well with no result, unless I did something wrong.
For this setup:
Channel A connected to Vout
Channel B connected to Vb <-- Saw wave
Channel C connected to Vc <-- Sine wave
Channel D connected to Xfade in (second half of the 257t Voffset and used it as a 0 to 10v source)
Xfade in at about 0v, Vout is strong saw:
Xfade in at about 5v, Vout showing transformation to sine (caught the sample off a bit, shrug):
Xfade in at about 8v, Vout still showing some saw in the troughs:
Xfade in at about 9v, Vout looks pretty sine (zoom would be cool, IDK):
Xfade in at about 10v, Vout is similar to 9v output:
feelingthin
Thanks! Where was the crossfade knob position? If fully counter clockwise, then a 0-10v envelope would fully crossfade to the other signal and mean it's -5/5v. So, if the knob is in the middle, it acts as an offset and a 5v lfo swings to Vb at -5 and Vc at +5. Or does the knob not act as an offset and I should use an envelope or bipolar lfo at 10v to crossfade fully?? That's the question
Spanningtree
feelingthin wrote: Tue Nov 15, 2022 11:20 pm Thanks! Where was the crossfade knob position? If fully counter clockwise, then a 0-10v envelope would fully crossfade to the other signal and mean it's -5/5v. So, if the knob is in the middle, it acts as an offset and a 5v lfo swings to Vb at -5 and Vc at +5. Or does the knob not act as an offset and I should use an envelope or bipolar lfo at 10v to crossfade fully?? That's the question
Broke the lab setup down for the night but the knob was fully ccw during those shots. Hope that helps! Might take a another look tomorrow, time permitting.
feelingthin
Spanningtree wrote: Tue Nov 15, 2022 11:26 pm
Thank you! That was very helpful! I have so many different voltages in my system, and just trying to match them correctly,
adnauseam
Post by adnauseam »
feelingthin wrote: Wed Nov 16, 2022 1:38 am
Recently I've been thinking about how nice it would be to measure and catalogue modules voltage expectations. Many times I've wondered why certain modules don't trigger others or wondered if I'm getting the full control over CV inputs with some of my modules.
Having this kind of information would also help make decisions about module pairings.
oliverkollar
Post by oliverkollar »
0-10v
If you have the crossfader knob at 7:00, 10v will open it fully to 5:00.
feelingthin
Perfect, thanks!
topherc
Post by topherc »
Has anyone else noticed a difference in triggers between modules in the range. The end of cycles triggers of the 281t won't trigger a few of my modules but the triggers from the 245t (i.e. pulse out or stage outs) trigger the same modules fine...
mritenburg
Post by mritenburg »
topherc wrote: Thu Nov 17, 2022 2:40 pm Has anyone else noticed a difference in triggers between modules in the range. The end of cycles triggers of the 281t won't trigger a few of my modules but the triggers from the 245t (i.e. pulse out or stage outs) trigger the same modules fine...
This is true of the 4U versions as well. There are a variety of pulse shapes implemented across the Buchla product line that result in triggering anomalies. There is a chart that floats around in posts here showing the pulse shapes across different modules in the Buchla product line.
topherc
Post by topherc »
mritenburg wrote: Thu Nov 17, 2022 2:47 pm
Interesting. Thanks. I wonder why Tiptop decided not to iron out those sorts of things.
cscairney
Post by cscairney »
can anyone attest to those quirks adding to the buchla 200 character? or is it just more frustrating than anything?
ProggyBoog
Post by ProggyBoog »
topherc wrote: Thu Nov 17, 2022 3:54 pm Interesting. Thanks. I wonder why Tiptop decided not to iron out those sorts of things.
I believe the goal has been to get the entire experience as accurate to the originals as possible. Even to the level of not providing manuals of any use whatsoever.
mritenburg
cscairney wrote: Thu Nov 17, 2022 3:57 pm can anyone attest to those quirks adding to the buchla 200 character? or is it just more frustrating than anything?
It’s just how it is. It’s generally not a big deal in Buchla 200 4U which is mostly(though not entirely) a closed format. Overall, the unique character and craziness that can result from patching a nice collection of Buchla 200 modules greatly outweighs this particular quirk.
I can see how in euro this can be more frustrating, however this issue comes up when mixing other brands of euro modules anyway.
luketeaford
Post by luketeaford »
ProggyBoog wrote: Thu Nov 17, 2022 4:52 pm
I am a Buchla skeptic but the TipTop manuals are pretty useful and the modules are way more fun than I expected.
The Junglechrist
Hey there folks,
I've made this little thing on my Tracker, using only samples from the tips & tricks video I linked earlier about the 245t and 257t.
Those TT / Buchla stuff are simple awesome.
samuelous
Post by samuelous »
Too bad the 292t & 266t aren't released yet, until I have the complete set I've decided to complement the modules with a MI Ripples, works pretty good even though its more in the subtractive realm.
luketeaford
samuelous wrote: Mon Nov 21, 2022 1:27 pm Too bad the 292t & 266t aren't released yet, until I have the complete set I've decided to complement the modules with a MI Ripples, works pretty good even though its more in the subtractive realm.
Welcome to the forum! Cool jam-- cool to have 2 nice oscillators for the size and price and you can even sorta get some subtractive synth action going with CV of the shape crossfader...
