Toppobrillo Sport Modulator 2 – how to use?
megarat
Re: Toppobrillo Sport 2 – how to use?
Post by megarat »
floher wrote: Mon Jun 27, 2022 11:06 am I’d be super interested in the previously asked question, whether you can invert a signal (or gate) with SM2!
Also, how do CV1 and CV2 differ from each other?
Re: your latter question, my understanding is that CV1 and CV2 sum to each other to affect the rate. CV1 has the attenuverter to let you tweak your desired CV accordingly, while CV2 is calibrated to track at roughly 1V/oct.
Re: your former question, I'm not sure myself, but if no one else provides an answer, I'll give it a whack.
:drunkbanana:
Naive Teen Idol
Post by Naive Teen Idol »
CV2 tracks 1v/oct
Edit: Already covered
kugua
Post by kugua »
One method to get the inverse of a gate would be:
Send 5v into the signal input, with the knob all the way cw. Send the gate you want to invert into the “hold” for the same input. The output should now go high when the gate is low, and to 0v when the gate is high.
floher
Post by floher »
Since the module is now in my hands, I actually found out that you'll just get an inverted gate at END by sending a gate to IN.
Actual voltage inversion, I haven't been able to figure out though...
toppobrillo
Post by toppobrillo »
floher wrote: Fri Jul 01, 2022 6:42 am Since the module is now in my hands, I actually found out that you'll just get an inverted gate at END by sending a gate to IN.
missed this. yeah you’re exactly right, this is a simple way to invert gates.
voltage inversion, not possible in any straightforward kinda way..but theres often weird creative workarounds depending on yer application to get you close enough, since this is a slew, you can patch an offset into the input and use the gate input to drive the output low at a slew rate you’ve set. with the right logic, you could use this patch to convincingly invert the action of simple envelope , lfo, etc.
Durdee
Post by Durdee »
mdoudoroff wrote: Wed Feb 23, 2022 3:52 pm Rough draft: Sample & Hold
Comments?
I know I’m really late to respond to this but I’ve found that I don’t get traditional sample and hold stepped voltage unless I have the cycle switch in the up position. When it’s up, then the rate knob adjusts the attenuation of the resulting voltage. If “cycle” is in the down position, I get a sort of noisy version of the input voltage or at least that’s what it looks like on my crappy little pocket oscilloscope.
ljwall83
Post by ljwall83 »
Durdee wrote: Sat Jul 02, 2022 6:37 am
Comments?
No that doesn't sound right. With CYCLE off (I.e. down) and MODE stepped (I.e. up) you should get a pretty standard sample and hold. My understanding is that the RATE knob adjusts how much the OUT cv can jump when a new sample is taken. Full clockwise and it can change fast so it'll jump to the new value; turning counter clockwise limits how far the OUT cv can jump when a new sample is taken (which may have a similar effect to attenuation- you'll likely end up with values nearer to zero)
Durdee
Post by Durdee »
Right on. The function is definitely operating properly as you described it, but I have to have the cycle switch in the up position for it to do so. I tried to figure it out by referencing the SM1 manual but I think some fundamental changes to the core functions have been made and also, this module is deceptively complex. Regardless, it’s a learning experience which I enjoy puzzling over.
ljwall83
Post by ljwall83 »
Hmm, that's what I think is odd, I don't think you should need to have the cycle switch up, in fact with the CYCLE switch up it should be ignoring what you have at the IN jack entirely and just doing stepped cycling :hmm:
Durdee
Post by Durdee »
Yeah, that’s what I thought! I’m confused. Maybe Josh can shed some light on this!
Jumbuktu
Post by Jumbuktu »
Sorry if this has already been covered elsewhere - are there any plans to gather together the patch diagrams displayed in this thread into a condensed document?
mdoudoroff
Post by mdoudoroff »
Jumbuktu wrote: Sun Jul 03, 2022 7:10 am Sorry if this has already been covered elsewhere - are there any plans to gather together the patch diagrams displayed in this thread into a condensed document?
Yeah, there’s a link way back on page 4 to a PDF compilation.
https://www.modwiggler.com/forum/downlo ... ?id=113471
I’m still waiting on a manual so I can go back and further correct/clarify the patches.
Jumbuktu
Post by Jumbuktu »
mdoudoroff wrote: Sun Jul 03, 2022 7:21 am
Thanks! I suspect your recipe book is going to be more useful than a manual - although it would be useful to clarify the details.
Mixcatonic
Post by Mixcatonic »
New SM2 arrived yesterday a few days earlier than anticipated - great stuff from Toppobrillo, and a nice surprise to have the module in hand for the long weekend!
Curious if there are any general strategies regarding jumper settings when used in systems with a lot of 0-10v modules such as Verbos? I’ve currently set the top half to unipolar and the bottom to bipolar for diversity and now wondering if this will lead to limitations down the line, for example with patches that may rely on complex patterns from the comparator. How are you all setting the jumpers in terms of both unipolar, both bipolar, or mixed with the choice of either unipolar on top vs bottom?
analogbrainsurgeon
Post by analogbrainsurgeon »
My SM2 also arrived ahead of schedule, now I'm really looking forward to trying the patches mentioned earlier in the thread and tieing SM2 into my video rig.
toppobrillo
TME wrote: Sun Jul 03, 2022 12:26 pm New SM2 arrived yesterday a few days earlier than anticipated - great stuff from Toppobrillo, and a nice surprise to have the module in hand for the long weekend!
If you want the comparator and RVG patch to operate properly, set both jumpers up the same- both uni or bipolar. it's really up to you. If you are used to patching maths/ DUSG clones that cycle from 0-5 or 0-8V, you might want to set them to cycle unipolar.. was just an easy option to add.
ljwall83 wrote: Sat Jul 02, 2022 6:59 am
Comments?
yeah , what they said. if your unit is not operating properly ,please send us an email for support.
weswog
Post by weswog »
Just hooked mine up yesterday I’m smitten!
KittenVillage
Post by KittenVillage »
I opted to have the Multifilter 2 and the Sport Mod 2 shipped together. I've been pinging the filter for a couple hours and patching the Sport Mod into it. Those two are are going to live together on my rack from now on. Can't wait to give the patch book a go over.
toppobrillo
KittenVillage wrote: Wed Jul 13, 2022 4:37 pm I opted to have the Multifilter 2 and the Sport Mod 2 shipped together. I've been pinging the filter for a couple hours and patching the Sport Mod into it. Those two are are going to live together on my rack from now on. Can't wait to give the patch book a go over.
:sb: they are a great pair indeed
Raymond
Post by Raymond »
Sometimes ago I made a patch to recreate the digital oscillator patch (on page 3 of this thread) feeding the top in with the sine and square wave of a Rubicon. I was sending the pitch sequence to the Rubicon and the SM2 at the same time if I recall correctly (to the CV1) and something incredible was happening. It was more sounding like a filter or wavefolder or something like this I don't know but it was marvelous. If I was bringing the volume of the square wave (going through a vca first) high enough with low pitch, the sound was being slowly destroyed in an astonishing way and then... it was stopping the sound completely ! The only way to start it again was to bring back up and down one of the switch but I don't remember which one.
Anyway long story short I tried to recreate the same patch yesterday and I failed miserably... But it brought me somewhere else. In the end I used the SM2 to modulate the cutoff and the FM1 of Polaris and also to send gates to Quadrax. Used Generate 3 to make a drone and the Rubicon is the other sounds on the sides of the stereo spectrum. Orbit 3 is modulating several stuffs here are there. THE SM2 IS SO GOOD !
PS : Now that I am looking back at the picture of the patch on page 3, I think I know what I did wrong this time ! I'll try again and RECORD IT THIS TIME in case I succeed.
Links to the music (new release Brèves d'un instant Mars 2023)-->
https://linktr.ee/soundofraymond
Link to videos —>
https://youtube.com/channel/UC33YEW1KNg-4KCg2XRnR8sw
MoS-squared
Post by MoS-squared »
Raymond wrote: Sat Jul 16, 2022 12:17 pm
Oh, please do.
Volion
Post by Volion »
Very useful thread, thank you for the examples.
ManBearPig
Post by ManBearPig »
Having trouble finding a breakdown of Sport Mod 2's front panel - what all the in/outs do. Are there any plans to update the patchbook with a breakdown like this, or point me in the right direction to where it's already explained?
informationsource
Post by informationsource »
ManBearPig wrote: Thu Aug 11, 2022 4:45 pm Having trouble finding a breakdown of Sport Mod 2's front panel - what all the in/outs do. Are there any plans to update the patchbook with a breakdown like this, or point me in the right direction to where it's already explained?
Previous page of the topic:
I don't know if it's 100% accurate but it is the best I've seen so far. More study required, of course.
mdoudoroff
It’s annoying that Toppobrillo is avoiding giving us even a basic manual, but then again, Cwejman and Buchla didn’t really provide manuals, either.
