Last Three Modules Purchased
- cinnatoastg
- Veteran Wiggler
Re: Last Three Modules Purchased
IME Kermit MK3
WMD Metron
WMD Voltera
WMD Metron
WMD Voltera
- crackerjackslacker
Rossum-Electro Linnaeus
ALA Rainier
Klavis Tweakers
ALA Rainier
Klavis Tweakers
-crackerjackslacker
today I bought this wifi sampler from atonal, the wvr
I am SO CURIOUS to hear how you like this WVR module. Did you get the 2HP trigger expander?
- MindMachine
- weekend warrior
mhtones wrote: ↑Tue Apr 11, 2023 7:30 pm Sputnik Variable Waveform Generator - This thing kicks out bass![]()
Livewire Vulcan Modulator/Mindmeld - 2nd set for me. These and the Kermit mk1 are my favorite LFOs. Guess I like pre-patched crossmod.
Toppobrillo Minimix - 2nd one for me. Needed one for my TipTop Buchla case. Come on 292t, where are you???![]()
'Sputnik Variable Waveform Generator - This thing kicks (out b) ass!'
I love mine. Tons of sound. Good w/ a Matrix Mixer for incoming cv's and outgoing waveforms into VC Mixer on drones and sequences. Creates a tapestry with one VCO. It's really well thought out and sounds great in any use.
Also, you may want to check out the old Pittsburgh Modular Bender - cross modulated madness for LFO action.
Visit the Santa Susana Field Lab
https://en.wikipedia.org/wiki/Santa_Sus ... Laboratory
Acl dual vcf and acl discrete Vco. Rippps
Thanks for the recommendation! I’ve never tried any Pittsburgh Modular modules. Will have to check it out. Although it doesn’t look like it has a reset which I find is great for making LFO madness stay in sync with music.MindMachine wrote: ↑Thu Apr 13, 2023 8:57 pm Also, you may want to check out the old Pittsburgh Modular Bender - cross modulated madness for LFO action.
FS/FT (US): Livewire Frequensteiner, Mosaic 1u 4 channel mixer, NLC 1u voltage controlled switch
- Boneoh
Doepfer 189-1 VBM
LZX Swatch
LZX FKG3
LZX Swatch
LZX FKG3
Ritual Electronics - Amnis
Mystic Circuits - Leaves (to accompany the above)
Flight of Harmony - Facehugger (Kickstarted)
- morphmuse
Joranalogue Select 2
Joranalogue Orbit 3
Nonlinear Circuits Statues
Nonlinear Circuits Hyperchaos Deluxe
Nonlinear Circuits Resonate
(Yes, that's more than 3, I know)
Joranalogue Orbit 3
- SmartBits
- Veteran Wiggler
Make Noise Echophon
Make Noise Mysteron
Make Noise QMMG
Party like it's 2014!
Make Noise Mysteron
Make Noise QMMG
- Ultra Wiggler
Finally found a Scales that was not horribly overpriced on the used market. Just a little more than the new price. It is on the way.
4MS SISM four channel offset attenuator. Every system needs one of these.
Pam Pro. I love Pam. Is she single?
uPlaits Beehive. Needed a full voice for my Pod. Small size does not bother me as I will mostly use CV to vary the sound.
Sometimes I feel like the Red Green of modulars.
- DigitalCrickets
Endorphin.es Ground Control
WMD MMF
Intellijel Flurry
WMD MMF
Intellijel Flurry
May the electrons always flow in your favor, and may the voltages remain under your control!
https://www.modulargrid.net/e/racks/view/2206807
https://digitalcrickets.bandcamp.com/
https://soundcloud.com/digitalcrickets
- Kattefjaes
A Kinks clone, to cover some bases.
A pair of Rack Plumbers (you need two to be useful, so I'd count it as one module).
Happy Nerding Isolator V2.
Pretty utilitarian QoL stuff, though the Isolator has the potential for irresponsible fun coming out hot through the transformers.
- SmartBits
- Veteran Wiggler
There were not many available, no. I had one coming in from the US, but the postal service messed that one up. Snagged up one from ModularGrid, from Italy.
hey me too!
NLC Resonate
FC Klang Stadt
FC System X Dual ADSR
FC Klang Stadt
- Ultra Wiggler
Well done!SmartBits wrote: ↑Tue Apr 18, 2023 8:36 amThere were not many available, no. I had one coming in from the US, but the postal service messed that one up. Snagged up one from ModularGrid, from Italy.
Bastl Ikarie, Waver and Akidio
- warrior_ant
- Learning to Wiggle
Squarp Instruments Rample
Fully Wired Electronics Mini Logic
and I haven't purchased it yet but Fully Wired Electronics Mini Quad Stereo Mute
- informationsource
Repurchased:
- Jolin Lab Agogo: so many LPGs in 6hp, great normalisations, sounds good too
- Mannequins W/ (Wslash/with): I never ended up using the tape mode since I first had it with the 2.0 firmware. Actually terrific fun, and just the 2hp weird sampler that I needed for my portable pod.
- WMD 4tten: said portable pod has PNW, Squid Salmple and a Quantus Ampla, and sliders to give 0-5V offsets are what makes it performable. Despite reservations some have expressed elsewhere, it does fit in a Pod64X just find, Pod walls have enough play in them.
