Prizes generously donated by:
ADDAC System (Eurorack 3U)
Endorphin.es (Eurorack 3U)
Studio.h (Buchla-format 4U)
4x Stereo Mix - 4HP 4-channel stereo mixer by Happy Nerding
igorrr
Re: 4x Stereo Mix - 4HP 4-channel stereo mixer by Happy Nerding
Post by igorrr » Tue Aug 10, 2021 1:12 pm
If you do not need amplification - it will work.
Otherwise, if amplification is needed – 2xSAM can be set with the jumpers as two channel stereo amping mixer.
Auxiliaryoctopus
Post by Auxiliaryoctopus » Tue Aug 10, 2021 1:47 pm
Great, thanks!
Squallaz
Post by Squallaz » Fri Sep 03, 2021 5:01 am
Any EU store have this available?
My Intellijel mixup bleeds like a monkey and the pots are noisy sometimes.
I hope the 4x Steremo Mix has better quality :D
Karl_Joseph
Post by Karl_Joseph » Fri Sep 03, 2021 9:10 am
No bleed on mine. Works impeccably. Silent with knobs at full attenuation
- KARL
woetjo
Post by woetjo » Sat Sep 18, 2021 9:21 am
This is a module I’ve been eyeing for a few months but it never seems to be in stock anywhere in the EU (my preferred seller is Schneidersladen) and since Brexit I avoid buying from the UK due to long shipping times and extra costs due to customs.
Any news on availability in continental Europe (EU)?
fastlanestranger
Post by fastlanestranger » Sat Sep 18, 2021 9:28 am
Just chiming in to say how much I’m enjoying this module. Finally heard some stereo effects last night from a unit I’ve been listening to in mono. Made me happy!
nathn
Post by nathn » Sat Sep 18, 2021 11:16 am
It looks like it's in stock at Escape From Noise.
woetjo
Post by woetjo » Sat Sep 18, 2021 4:08 pm
Thanks. I immediately ordered one from them.
megarat
Post by megarat » Sun Sep 19, 2021 1:49 pm
I have my fingers crossed for a restock at Analogue Haven.
igorrr
Post by igorrr » Sun Sep 19, 2021 3:39 pm
Fresh restock should arrive to AH in a couple of days.
megarat
Post by megarat » Sun Sep 19, 2021 3:59 pm
Outstanding, thank you for the update.
Bascule
Post by Bascule » Thu Sep 30, 2021 2:08 am
Thanks for all the updates!
May I ask if Schneidersladen will be getting some units any time soon?
igorrr
Post by igorrr » Thu Sep 30, 2021 9:06 am
Yes, they ordered 4x St. Mixers.
FletchNYC
Post by FletchNYC » Thu Sep 30, 2021 6:01 pm
How are people using headphones with this module? Is there a particular cord for this?
igorrr
Post by igorrr » Fri Oct 01, 2021 4:59 am
It is DC coupled mixer, so better not to connect headphones directly.
FletchNYC
Post by FletchNYC » Fri Oct 01, 2021 8:27 am
What if I connected it to the intellijel 1U Headphones module, and plugged headphones into that? Would that be a recommended solution?
igorrr
Post by igorrr » Fri Oct 01, 2021 11:16 am
Yes, do not see a reason why it may not work.
joewheela
Post by joewheela » Sat Oct 02, 2021 11:06 pm
Anyone tried connecting these to the 1/4 jacks intellijel pallette case? Looks like a pair of 3 pin connectors on the 4x, and a 6 pin on the intellijel board (2x TRS sockets). Seems like it should be possible to use one TRS as stereo-in and the other as a stereo out?
Kosmikos
Post by Kosmikos » Sun Oct 03, 2021 2:57 am
Sounds as bad as an idea as plugging your headphones directly in tbh.
I’ve been trying to better understand AC and DC coupling after reading Igorrr’s answer, the point is a DC coupled module doesn’t filter low frequencies in order to allow CVs to pass through, including DC offsets.
AC coupled modules can filter these offsets, and therefore can be kept in check to +/- a few volts without damaging your line level equipment.
So now imagine, you’ve plugged a 10V offset onto the 4x St mixer by mistake, then get that straight out to the 1/4 jacks of the case, what’s next, where do you go from here? Plug this onto a line level synth or mixer input? :eek:
I think you need at least an AC coupled module as the last element of the chain before the 1/4 jack outputs, less likely to damage your equipment. Unless your are thinking plugging it to another Eurorack level, but if you are using 1/4 jacks I suspect that’s not your intention?
(Might also be working tor 5U modular, apart from that I’m not quite sure.)
Either that, or get either the Intellijel Stereo Out or Stereo Headphones, which also reduces the hot output to something that won’t saturate your connected equipment.
Reference:
https://noiseengineering.us/blogs/loque ... what-is-it
joewheela
Post by joewheela » Sun Oct 03, 2021 5:01 am
I always plug straight into my mixing desk and use the gain to control the level. Never had a problem.
igorrr
Post by igorrr » Mon Oct 04, 2021 11:03 am
Schneidersladen store was shipped today.
Wavtekt
Post by Wavtekt » Mon Oct 04, 2021 2:52 pm
I think the annoying part is DC mixer introduces click and pops etc, if your audio in have slow DC signals.
1. Using a slow LFO to modulate the wavefolder symmetry.
2. Use a slow Function Generator to modulate the frequency of a VCO (i.e. vibrato).
Too bad this mixer is DC coupled, rather than AC coupled like Mixup or Hyrlo. Otherwise, I am interested in buying one.
igorrr
Post by igorrr » Mon Oct 04, 2021 3:14 pm
This is VCA based mixer, so the signal is not passing through the potentiometers thus does not have artifacts during twists if DC is present.
Wavtekt
Post by Wavtekt » Mon Oct 04, 2021 4:43 pm
hmmm .. I think I got it now, so this mixer uses SSI 2164(?) VCAs and the pots are actually changing the CV Bias of the VCA, so whether it is DC or AC coupled doesn't matter much because this mixer are way-less prone to bleed / crosstalk etc. like all other mixers do?
I tried to use a DC coupled VCA with Intellijel Stereo out 1U to simulate what will happen if I mixed a DC offset accidentally to the audio input of a DC coupled mixer. The audio signal will still be distorted in certain extreme conditions, so VCA headroom might be an issue if it is DC coupled. Meanwhile, an AC coupled mixer completely eliminated that issue.
I think the best practice is still to use an AC coupled mixer to remove any DC signal from modules, since analog modules like oscillator / filter etc. are imperfect and they all have some DC offset in certain extent, although most likely it is only in mV.
