Panning and cross-fading
EATyourGUITAR
has no life
Re: Panning and cross-fading
Post by EATyourGUITAR » Wed Jul 29, 2020 7:16 am
although I do need a full wave rectifier module and an offset module, I don't know if this big thing is better than a 2HP FWR + a 4HP SPO. the SPO has 2 2 input mixers. with flying attenuators, this becomes 2 2 channel mixers in 4HP + invert attenuate offset post mix. I am already selling off big modules to buy smaller ones.
teamhobson
Post by teamhobson » Wed Jul 29, 2020 7:18 am
skreetis wrote:
Sat Jul 25, 2020 9:51 pm
Radomil wrote:
Sat Jul 25, 2020 9:43 pm
That seems like an amazing combination! I didn't think of the planar 2! It seems like it gives a lot of control, do you know if it can completely Crossfade two signals using CV? Like something the xfade can do? I may pick one up because if it can, it can also be used for lots of other tricks!
It can’t crossfade natively, but it’s a great CV source for easy crossfading if you have two VCAs.
EDIT: Actually, I think I’m wrong about that. I’ve never used it that way, and I don’t have it on hand at the moment to test it out, but I’m pretty sure if you patch in four sources, you can crossfade between them via the MIX out. Sorry if I’m spreading bad info!
Can confirm that Planar 2 can crossfade between 2, 3 and 4 signals without use of a VCA via the MIX output. Very useful module indeed.
It can also do standard panning and quadraphonic panning, if you have such a set up.
I regularly have to remind myself of the planar2s capabilities as I more often than not just use it as a source of interesting CV. Going to try some crossfading with it tonight :sb:
Rex Coil 7
Post by Rex Coil 7 » Wed Jul 29, 2020 7:18 am
Not to mention recording stick movements and playing them back at will ...
skreetis wrote:
Sat Jul 25, 2020 8:35 pm
... Planar 2 is also useful, using its audio in, and its four outputs, to pan a source around the Soundstage.
Chookity Pok!
5U MODULAR NORMALIZING PROJECT https://www.muffwiggler.com/forum/viewt ... highlight=
There are four fingers no matter what the party tells you .... Never Quit, Die Falling Forward.
OHEXOH
Post by OHEXOH » Wed Jul 29, 2020 10:04 am
The problem with Planar 2 (vs. Planar 1) is the digital noise which is present on the outputs. In my opinion this noise makes it unusable for audio sources - certainly with any quieter more ambient audio sources
OHEXOH
Post by OHEXOH » Wed Jul 29, 2020 10:06 am
EATyourGUITAR wrote:
Tue Jul 28, 2020 5:13 pm
OHEXOH wrote:
Sat Jul 25, 2020 2:07 pm
Dual XFade from Happy Nerding is great except it requires 6V to go from A > B. It's such a weird requirement - most of my modules (especially gate outputting modules) put out 5V.
I wanted to use it as a Switch but I can never fully crossfade the thing. What's frustrating is there's no manual or mention of that on their website. :hmm:
I was about to buy one of these. thank you for telling me. this must be an easy fix by changing 4 resistors. do you have high res pictures?
If you have a good source of bi-polar CV then -5 to +5 will send it from A to B when the mix is set to the middle. But yeah when Mix is set to fully A to send it to fully B it takes around 6v.
EATyourGUITAR
has no life
Post by EATyourGUITAR » Wed Jul 29, 2020 10:25 am
if it works with 6v it will also work with 10. I'm waiting for pictures. if I can't customize this flaw then I will not buy it. I want to see if it is stacked and socketed. do you feel like taking pictures for me?
dooj88
Post by dooj88 » Wed Jul 29, 2020 2:21 pm
jeez, i completely forgot i did that. it was a while back, but i think i was panning rings back and forth between 4 different fx.
Riggar
Post by Riggar » Thu Jul 30, 2020 5:54 am
twos up for ladik a-410 - does the job (panning) nicely
1960strat
Post by 1960strat » Thu Jul 30, 2020 9:39 am
I would recommend the Verbos scan and pan, i think it can also crossfade, but may be wrong
Foghorn
Post by Foghorn » Thu Jul 30, 2020 12:13 pm
Ladik Pan/mix (A-410) - recommended
EMW VC Pan - also good
or if you don't mind replacing chips all the time
Doepfer A-134
I think the a-134 only fries chips when you put in a negative rail without a positive one.
Like when you turn on or off the case and the supplies go up or down at different rates.
In other words, sometimes, every time you turn on or off the case. :bang:
I have only ever used any of these for auto panning (stereo)
Stay Calm - We are in this forever :hmm:
.......Steven Banks wannabe.......
I am an under the influencer
EATyourGUITAR
has no life
Post by EATyourGUITAR » Thu Jul 30, 2020 1:09 pm
if there is a 2164 inside then that would support that. this is the only confirmed myth I know where a module will completely fail if the negative rails powers up before the positive rail. there is a fix posted in the DIY section a long time ago. either doepfer can redesign it to have protection or you can perform the mod yourself. I would rather buy something and mod it then not buy it at all. I guess that depends on if you like to do mods or can do mods etc...
valouxxx
Post by valouxxx » Thu Jul 30, 2020 4:02 pm
The Verbos scan and pane could do the job!
Foghorn
Post by Foghorn » Thu Jul 30, 2020 4:24 pm
Yes, a V2164.
I must of put 7 or 8 in before I finally figured it out.(I bought a dozen from Mouser)
Actually I put in sockets for quick changes.
My solution was the EMW pan, and then the Ladik Pan modules.
Now I will stop hogging this thread for things that are not pertinent.
OHEXOH
Post by OHEXOH » Fri Jul 31, 2020 11:28 am
Will DM you some pics
windchill
Post by windchill » Fri Jul 31, 2020 11:54 am
So many answers here recommending modules for panning that do not implement a proper pan-law.
:bang:
Though the ADDAC 805 pans properly according to ADDAC.
Ladik, Cold Mac, Planar II, MN X-Pan, and a whole bunch of other Eurorack panners and crossfaders are linear.
EATyourGUITAR
has no life
Post by EATyourGUITAR » Fri Jul 31, 2020 4:17 pm
Two people sent over the pictures of the happy nerding crossfader. I will publish instructions to do the mod all open source etc.. no disrespect intended towards Igor. I think we can change resistors after we buy the module. I probably don't need or want to publish a full schematic. I'm not trying to encourage anything that hurts the business. I will post it in the DIY section later. People can stop sending me pictures of the module now since I already have it thank you.
EATyourGUITAR
has no life
Post by EATyourGUITAR » Fri Jul 31, 2020 6:17 pm
I wanted to say that the happy nerding dual xfade is capable of operating in unipolar mode with only 5v after some resistor changes. I did look at it but I need to buy one to confirm that the mod is working before I post instructions. the CV input goes into a rectifier into a buffer into a mixer with the knob CV then into another buffer. it has TL072. super easy to figure it out.
pugix
Post by pugix » Sun Aug 02, 2020 11:25 am
Mon Jul 27, 2020 8:39 am
a really great module here.
https://starling.space/via/meta
the only reason I did not buy is size and price. maybe it works for you.
Agreed, great module. It's perfect for cross-fading, because the control for fade between A and B is internal and always perfectly goes from 0 to 100% signal across the fade. And it has a built-in generalized contour generator for every shape and rate you ever need to control the fade.
https://pugix.com/synth/starling-via-meta/
I have two of them. Yes, it's large, but very multi-function. However it does not do panning, only cross-fading.
Richard
https://www.pugix.com
Dcramer
Post by Dcramer » Mon Aug 03, 2020 11:37 am
Yes, a V2164.
Yikes! :doh: This is the first I’ve heard of this problem with the Doepfer planner. I’ve had an old version for years (only passes audio, not DC) but I just put a newer version in my rack This week. It’s the ver 2 from 2013 that also passes DC. Which version blows up?
I’m using tip-top uZues power with them :help:
EATyourGUITAR
has no life
Post by EATyourGUITAR » Mon Aug 03, 2020 11:41 am
do you see 1N4148 close to the 2164? if no then it is not protected.
SlagRalden
Post by SlagRalden » Tue Dec 01, 2020 1:57 pm
why does the panmix jr not have cv control?!? :cry:
would be the exact module I'm looking for if it did..... maybe igor could make a 2hp expander?
I have the xpan and its awesome but it only has a mix output... :doh:
windchill
Post by windchill » Tue Dec 01, 2020 2:21 pm
Many of the suggestions so far are linear panners. This may be ok for basic needs and special effects but be aware that there will be an unnatural volume dip. This may not matter to you but it’s best to be informed.
banalytic
Post by banalytic » Sat Dec 26, 2020 10:08 am
Yes, a V2164.
I was about to order the doepfer A-134 PAN (MKII) and before that I came across this thread.
I have an Intellijel Designs 7U Stealth Case 104 HP and would like to know if someone can tell me if the power supply on this case is causing problems with the module ?!
Dcramer
Post by Dcramer » Sun Dec 27, 2020 12:17 pm
🥸 I’m so forgetful I’ve forgotten to even check mine? Lol
So far both of my Doepfers have been fine with my tiptop uZues supplys 👍
banalytic
Post by banalytic » Sun Dec 27, 2020 2:09 pm
After this information about broken modules, I am just a little unsettled ... is this a problem that affects DIY cases or also "professional" ones?
