Doepfer A-149-4 Polyphonic Random Voltage Source
Foghorn
Re: Doepfer A-149-4 Polyphonic Random Voltage Source
Post by Foghorn »
Rigo wrote: Thu Apr 30, 2020 7:09 am
Dieter on the Doepfer A-100 group wrote:Though the preliminary name of module A-149-4 is "Polyphonic Random Voltage Source" the applications are not limited to polyphonic structures. It just will generate 4 random voltages with a separate trigger input for each voltage. The type of randomness is controlled by several parameters. Maybe we should rename it to "Multiple Random Voltage Source" to avoid misunderstandings.
And both the Fluctuating Random Voltages and the Chaos modules are not yet dead (as well as the new frequency shifter and the pitch-to-voltage module).
Can anyone tell me about the chaos module(s) mentioned above. IE.. name or number
I can not seem to find anything on Modulargrid.
.......Steven Banks wannabe.......
Rigo
Chief Spam Killer
Post by Rigo »
Foghorn wrote: Tue Jan 11, 2022 7:56 amCan anyone tell me about the chaos module(s) mentioned above. IE.. name or number
Look for "149-3" on this page:
https://doepfer.de/a100_man/a100_patch.htm
I don't know if there are other places where this module is mentioned.
beat4less
Post by beat4less »
Finally available !
Quite sexy interface for a Doepfer module, but I don't really get what it's for.
Quad random polyphony... Seriously, who want/use that ?
I'm really curious if you care
nhalda
Post by nhalda »
beat4less wrote: Tue Jul 12, 2022 2:59 pm Quad random polyphony... Seriously, who want/use that ?
I'm very interested. I've been looking at a way to do pretty much exactly this for a reasonable price and I think it'll be hard to beat.
I can't seem to find any specifics on the exact differences between scale and chord mode. Anyone have any insight?
Jumbuktu
Post by Jumbuktu »
beat4less wrote: Tue Jul 12, 2022 2:59 pm Finally available !
Are you kidding???
The DivKid Random module does 6 random outputs and it's a popular module. I have used all 6 at times. The Buchla Easel has 3 randowm sources. I am excited for the Doepfer module. I won't be using it for polyphony, but I think Doepfer just positioned this as part of their quad polypohony suite.
beat4less
Post by beat4less »
Yep, I’m wondering about the quantized feature, and looking for examples
moo_lefty
Post by moo_lefty »
The doepfer site itself hasn't updated this as available but I've had one for a couple of weeks (ordered as soon as available from Juno UK)
It's great! Mainly use it to feed a Shakmat Bard Quartet - may sound weird putting quantised voltages into a quantiser but can easily manipulate the key/scales
I'll try and put a vid together this weekend (but am generally terrible at that)
7C
Post by 7C »
the only vid so far - i think it's in german but there are subs...
thymeandplace
Post by thymeandplace »
Rigo wrote: Tue Jan 11, 2022 8:10 am
I was wondering what happened to A-149-3 and this answers it. Thanks.
Looking forward to this module if it ever comes out.
Jumbuktu
Post by Jumbuktu »
Finally got mine!
It's a few mm deeper than it needs to be to fit in a Intellijel Palette case, but there is a pin header on the bottom board that is the only issue. Anyone know what it's for? Maybe an expansion? I am half inclined to clip the pins off or bend them sideways to make it fit.
Ebotronix
Post by Ebotronix »
which minor scale is used in A 149-2 for chords and scale? can someone check the halftone/whole tone steps?
Ebotronix
Post by Ebotronix »
I asked Doepfer. in the final firmware there should be the possibility to set the minor scale to : Aeolian, harmonic 1/2 melodic and Dorian with the switches +6 and +7.
can someone test this?
feelingthin
Post by feelingthin »
Does this module output up to 10v? I see the range knob goes to 10, but the website says 5v. That could be a typo. I'm confused. Thanks!
erstlaub
Post by erstlaub »
Nah, as far as I've noticed it's probably just 5v, I mean, that's 5 octaves, if you need a 10 octave span you're probably going to need something else. I could be wrong though as I've only ever really run it over a few octaves. I think all Doepfer knobs go to 10 regardless of what they are.
feelingthin
erstlaub wrote: Fri Mar 17, 2023 7:19 am Nah, as far as I've noticed it's probably just 5v, I mean, that's 5 octaves, if you need a 10 octave span you're probably going to need something else. I could be wrong though as I've only ever really run it over a few octaves. I think all Doepfer knobs go to 10 regardless of what they are.
Got it, that works for most applications. I'm not using it for pitch but to add some per step random for Verbos modules which are 0-10v. I don't plan on using this module for pitch. It really needs an offset control or octave switch to be used for melodies.
megarat
Post by megarat »
feelingthin wrote: Fri Mar 17, 2023 9:55 am
This prompted me to test this out on one of mine — range knob cranked CW, outputting octaves, and plotting the voltage on my O’Tool+ — and I’m seeing voltages get as high as 9V. I’m realizing now that it might get higher than that when using a finer resolution, like semitones.
:drunkbanana:
Jarls
Post by Jarls »
Got this module and using it mostly as a sort of monopolar S&H where I can set and control the output values and range directly on the module. Bonus is that you can sort of use it like a random quantized arp.
Only real dislike is that it does not remember it's button settings between power cycles.
If it had that - and an offset setting to its output it would be really great (I'm using it with a WMD Volt to transpose/offse the output).
BLogic12
Post by BLogic12 »
I can confirm my volt reader is reading a high of 9.9 volts (tested in the continuous unquantized voltage setting).
this is why i sold my frap tools sapel and replaced it with two of these. sapel only put out around 6v max (and rarely even hit that). not enough for my needs. this think is prefect, big range of potentail voltages and super useful built in quantization. couldn't be happier with it (except as stated, it would have been nice to hold settings on power cycle, but not a deal breaker by any means).
erstlaub
Post by erstlaub »
Wow, I guess I've not dug into it as much as I thought I had, that's cool, apologies for bum advice.
feelingthin
BLogic12 wrote: Fri Mar 17, 2023 1:55 pm I can confirm my volt reader is reading a high of 9.9 volts (tested in the continuous unquantized voltage setting).
Awesome, my initial thought was this would be awesome with the Stochastic Inspiration Generator. 4 gates and triggered random for each voice. I'm thinking of grabbing another because it seems so useful. I like the idea of quantized random for non-v/oct sources like filters, fm index, etc. Doepfer keeps putting out gold. He's the OG and still makes awesome stuff for good prices.
feelingthin
erstlaub wrote: Fri Mar 17, 2023 5:11 pm Wow, I guess I've not dug into it as much as I thought I had, that's cool, apologies for bum advice.
All good. I appreciate you trying to help! I'm sure a bum or two are known to be sages.
feelingthin
Jarls wrote: Fri Mar 17, 2023 1:21 pm Got this module and using it mostly as a sort of monopolar S&H where I can set and control the output values and range directly on the module. Bonus is that you can sort of use it like a random quantized arp.
Precisely why I like modules where knob position acts as the center point or offset for incoming voltage.
Dcramer
Post by Dcramer »
I’ve got one in my Doepfer polyphonic rack and have used it for pitch, it’s quite cool and packs a lot into a tiny space, I wish it had some CV control though.
If I get a chance I’ll do a little vid about it 👍
DigitalCrickets
Post by DigitalCrickets »
Pam's > A-149-4 > HEL > Odessa...
Yeah, this is a wonderful combo.
