DFAM Sequencer Module
arvelomcquaig
Post by arvelomcquaig » Fri Mar 20, 2020 8:07 am
Does anyone know of a (small, compact) module that works like the DFAM sequencer? That is, with eight (or 16) little knobs that you adjust for each step? It seems like such a basic/simple module functionality but I can’t find anything like that other than René, which is huge/expensive. Thank you!
Manresa
Re: DFAM Sequencer Module
Post by Manresa » Fri Mar 20, 2020 8:49 am
The old Pittsburgh Modular Sequencer is only 8 steps & unquantized, but fits the bill:
https://pittsburghmodular.com/sequencer
mdoudoroff
Post by mdoudoroff » Fri Mar 20, 2020 8:57 am
tdallas
Post by tdallas » Fri Mar 20, 2020 10:51 am
Does it have to be a rack mounted module? If yes, please stop reading :razz: If not, the Korg SQ-1 might be a possibility: Korg SQ-1
Tumulishroomaroom
Post by Tumulishroomaroom » Fri Mar 20, 2020 11:13 am
The 8s is probably the closest. For a bit more control/possibilities a couple XAOC Tirana II might work as well. Big and expensive there's the Verbos Voltage Multistage that does a ton more but is two rows of 8 (10v) CV sliders, see here :
instagram
Youtube : long-form module demos
data roaming 004 5 tracks compilation on cassette.
natureclubcassettes
Post by natureclubcassettes » Fri Mar 20, 2020 11:32 am
Octone!!
seta666
Post by seta666 » Fri Mar 20, 2020 11:37 am
My SQ1 is rack mounted, there is still room to add a 3u4hp module horizontaly and 2 trs jacks disting mk4 midi...a 1u26hp could also be mounted instead of the 3u4hp one.
I think is a dfam sequencer on steroids with two trigger/gates, polyrithms, slides, step jump...DFAM sequencer is a joke..
tdallas
Post by tdallas » Fri Mar 20, 2020 12:55 pm
I wondered how that might look like but than I‘ve found your modular grid link in the signature. This is pretty cool :tu: is that available somewhere or a private DIY project?
adnauseam
Post by adnauseam » Fri Mar 20, 2020 2:46 pm
I think your quest will be complete when you pop over to modular grid, click modules at the top, choose "sequencer" as the function and revel in the sheer variety of choices available to you.
seta666
Post by seta666 » Fri Mar 20, 2020 3:24 pm
It is not exactly that one, I used that one from modular grid as a reference. I just took the bottom part of the sq1 away and screwed two 90°black pvc plastic angles; they were cheap ( 3€) and almost the same size, still would fit a 3hp module. I have to look for the right ones ( one smaller than the other so there is room for a 5hp module). When properly finished top angle will have 2 trs inputs for disting mk4 midi in/out, SQ1 usb port and either a 3U3/5HP module or a 1U module like Intellijel 1U Noise Random Tools or similar.
Used this post as reference
viewtopic.php?f=17&t=168998
I also used one like this so I can connect it to a 5v usb phone charger or to the computer via ableton
https://es.aliexpress.com/item/32969463007.html?
anselmi
Post by anselmi » Fri Mar 20, 2020 9:51 pm
another vote for the SQ-1...they are cheap and versatile, and do what you are after
Silentnotes
Post by Silentnotes » Sat Mar 21, 2020 2:41 am
Octone!!
+1000
Its the best smallHP sequencer in eurorack but it seems only few people know or talk about it.
seta666
Post by seta666 » Sat Mar 21, 2020 6:04 am
Octone!!
+1000
I thought it looked nice until I saw the price, 300€. You need two for 16 steps sequence...600€
That buys you a SQ1 and DFAM..
Of course if mone is not a problem look like a nice little sequencer..but gor the cost of one octone I would rather get two dnipro's
https://www.modulargrid.net/e/dnipro-modular-metamorph
sb01
1-Post Wiggler
Post by sb01 » Sat Mar 21, 2020 9:10 am
How about Ladik S-180 + couple of S-182’s
Silentnotes
Post by Silentnotes » Sat Mar 21, 2020 10:11 am
Octone!!
+1000
I dont have a lot of money, thats exactly the reason I bought the Octone. You will eventualy want to add features to your simple and cheap sequencer, like quantizing, variable step lenght, individual gate outs, racheting and so on and it will cost you more (money and HP) then buying Octone from the start. There is a saying: I am not rich enough to buy cheap :tu:
p.s. and its not a "nice little sequencer" but the best in its size. Prove me wrong.
muleskinner
Post by muleskinner » Sat Mar 21, 2020 1:08 pm
Another recommendation on the SQ1.
Cheap and really flexible - can even be used as a basic clock divider, LFO, or envelope generator plus MIDI-CV converter.
Only downside is it can't be rack mounted without some innovative DIY - kudos to those who've managed it!
Jamming, Patching and Twiddling: http://bit.ly/facelessmule
Currently Selling (UK): Akemie's Taiko, Plaits
seta666
Post by seta666 » Sat Mar 21, 2020 4:51 pm
There are lots of powerful, interesting yet small sequencers; like prizma, euclidian circles, Pittsburgh Modular Game System etc...depending on your needs..
sko87pro
Post by sko87pro » Sat Mar 21, 2020 6:50 pm
Big fan of Ladik! I think that combo ^ would give 8 steps x2 CVs. To have 16 steps of CV would need another S-180 and also a switch for the clock, I think...?
Refs:
S-180
http://ladik.ladik.eu/?page_id=34
S-182
http://ladik.ladik.eu/?page_id=135
smithjohn
Post by smithjohn » Sun Mar 22, 2020 4:56 am
Yeah, a switch and a clock divider to switch between the two CV rows every 8 clock pulses.
arvelomcquaig
Post by arvelomcquaig » Sat Mar 28, 2020 9:09 pm
Thanks a lot for everyone’s suggestions! Since I have so little room in my Palette case, I think I’ll get an SQ-1 for now and then get a rack-mounted one later when I have a bigger case.
msboude
Post by msboude » Sat Mar 28, 2020 9:22 pm
I dont know if you have a dfam and are trying to get more steps out of your dfam.. but you can take the pitch row and the velocity out into a sequential switch, send that to vco in.. use a clock divider to trigger the sequential switch on /8 and you have a 16 step dfam
