Where are the Benjolins?
insoul8
Post by insoul8 » Tue Mar 10, 2020 2:16 pm
Now that Epoch seems to be out of the game at least for now from what I've heard (someone please correct me if I'm mistaken), are there any other manufactures that might take the torch and keep producing them for eurorack? They seem pretty damn hard to come by at this point. I tried one based on the Kweiwen PCB but it seemed to have some issues and I wasn't crazy about the lack of normalizations. At any rate, the Epoch seemed to be the best option. Anyone know if anything else might be in the works?
jorg
Re: Where are the Benjolins?
Post by jorg » Tue Mar 10, 2020 2:19 pm
Show me the Benjolins!
:75:
insoul8
Post by insoul8 » Tue Mar 10, 2020 2:21 pm
lol i almost wrote something like that.
It's All About The Benjolins...
didahdrieghe
Post by didahdrieghe » Tue Mar 10, 2020 2:51 pm
If you're into DIY, there's an SMD version here which seems to have fixed some of the problems the Kweiwen version had:
https://github.com/forestcaver/Benjolin
Still building mine so can't comment further on it yet though.
insoul8
Post by insoul8 » Tue Mar 10, 2020 2:56 pm
Thanks for the info. Nice to hear there are improvements to the Kweiwen version. Unfortunately I'm not competent enough to do a diy build myself and don't really foresee myself taking on another hobby like that. I have enough trouble finding time to record these days.
cliffemu
Post by cliffemu » Tue Mar 10, 2020 3:25 pm
I currently have a Kweiwen variant build, but I'm curious if anyone has tried one of these? Seems like a different thing but almost the same idea?
https://afterlateraudio.com/product/juggler/
colossus
Post by colossus » Tue Mar 10, 2020 3:41 pm
I had one. I never played a real Benjolin, but it sounded right compared to a Max/MSP emulation I had used in the past. Cheap too!
forestcaver
Post by forestcaver » Tue Mar 10, 2020 3:44 pm
On mine I havent heard any bleed on either of the ones I’ve personally built and not had any reports of problems.
I also:
- Added a gain cell on the output to boost to euro levels (rather than boosting pre-filter, which changes the sound)
- Added protection diode for the v2164 (to save the chip if a power rail goes down)
- Added diodes to ensure the two linear regulators come up ok, even if the psu has variable slew of the power-on rise
- Normalled the cv inputs from the oscillators
insoul8
Post by insoul8 » Tue Mar 10, 2020 3:59 pm
I also:
That all sounds great. Those were my only two issues I really had with the other design and it sounds like they aren’t a problem with your build.
brandonlogic
Post by brandonlogic » Tue Mar 10, 2020 6:49 pm
Juggler is the best one available in eurorack.
The epoch one and the old diy one both were very sensitive to power supplies, simply didn’t work on some power supplies. The filter outputs were quit. The juggler addresses both of these issues. Has the FM normalizations of the epoch one.
It’s available here. Only $200 built.
https://reverb.com/item/21478855-juggle ... y-benjolin
insoul8
Post by insoul8 » Tue Mar 10, 2020 7:30 pm
For all intents and purposes is this pretty much identical to a Benjolin? It looks that way to me but I don’t want something just inspired by the Benjolin, I want it as Rob intended it. Same Rungler circuit and such. I might have a lead on a different build but this price has my attention.
brandonlogic
Post by brandonlogic » Tue Mar 10, 2020 7:34 pm
Yes from what I understand it’s exactly the same other than the improvements I mentioned.
You can message them through Reverb, and ask if you want his official word.
Struggle
Post by Struggle » Wed Mar 11, 2020 1:22 pm
There’s a Epoch just posted in BST
insoul8
Post by insoul8 » Wed Mar 11, 2020 1:44 pm
That's very unfortunate they don't work in Doepfer cases. The seller noted that in the post. I only have Doepfer cases so I guess the Epoch is a no go for me.
trax
Post by trax » Wed Mar 11, 2020 2:00 pm
Yep. The Epoch guy did a few runs that did not work in doepfer cases and from what I can tell they had 2017 PCB's.
You need to power cycle them a few times for them to work in Doepfer cases....but in other cases with bricks - they work fine, every time.
If you don't use Doepfer - don't even worry about it - it's not even an issue.
BTW - i have a 2014 epoch modular benjolin that works perfect in Doepfer cases.....
dooj88
Post by dooj88 » Wed Mar 11, 2020 2:49 pm
why oh why don't these have blinkenlights
brandonlogic
Post by brandonlogic » Wed Mar 11, 2020 9:19 pm
just saw this up on perfect circuit, stand alone benjolin!
https://www.perfectcircuit.com/exagonal ... jolin.html
He_lium
Post by He_lium » Thu Mar 12, 2020 4:02 am
Epoch Benjo Twins
forestcaver
Post by forestcaver » Thu Mar 12, 2020 4:09 am
Is it licenced from Rob? I guess if they are advertising it as a “Benjolin” you’d hope they would have - I cant imagine anyone just ripping off his idea and using the Benjolin name.... :eek:
insoul8
Post by insoul8 » Thu Mar 12, 2020 7:36 am
I just heard from Rob on the After Audio Juggler and he says they are a blatant copycat undermining his work as a designer. They have never contacted him about using the design, and undermined the license agreement with Epoch Modular by outpricing the Epoch version.
forestcaver
Post by forestcaver » Thu Mar 12, 2020 7:56 am
That’s not good at all.... very not good.... it really undermines the community and will lead to less people being happy to share their work if their views are disregarded and disrespected. Poor show.
cliffemu
Post by cliffemu » Thu Mar 12, 2020 12:15 pm
What about this one? https://www.perfectcircuit.com/exagonal ... jolin.html
I guess things are getting out of hand since there's not enough retail availability of licensed products?
shred
desperation tentacle
Post by shred » Thu Mar 12, 2020 12:24 pm
I wouldn't say that. I had a 4MS Row 40 and the Epoch version did NOT like it. Sent it back for repair numerous times and every time I was told that it was working properly. Ended up selling it.
KittenVillage
Post by KittenVillage » Thu Mar 12, 2020 12:40 pm
I just got most of the smd on mine last night! (The printing on the board is so small! It made it a real challenge.)
Eurorack is an exercise in delayed desire.
forestcaver
Post by forestcaver » Thu Mar 12, 2020 1:49 pm
I just keep eagle open on my laptop when I’m building! (For my own builds I dont usually even bother creating gerbers with part numbers :-) )
