Video game inspired modules
NARC NOISE
Post by NARC NOISE » Fri Jan 24, 2020 10:47 am
So outside of Oscillographic Block and SID GUTS/SID GUTS DELUXE, what are some other lesser known oscillators that utilize chips from the good old days of NES and SEGA?
starthief
Re: Video game inspired modules
Post by starthief » Fri Jan 24, 2020 11:36 am
In rough chronological order:
I don't think there are any TIA chip oscillators for Eurorack, but there's a Midibox TIA standalone.
Analog Bytes POKEY.synth uses a POKEY chip.
Twisted Electrons AY3 comes to mind. That chip was used in a lot of classic arcade games, plus the Intellivision, Atari ST and others.
SynthTech E950 has the original ROM data and algorithms from TI LPC speech synthesizers, though I suspect the implementation is modernized.
Going forward to the early 90s, Akemie's Castle uses Yamaha OPL3 chips (several Sound Blaster models).
Not specifically using old chips:
There are a few LFSR based modules which will give you the same sort of classic low-bit noise and square sounds. Noise Engineering Ataraxic Translatron, EMW Arcade Noise, The Harvestman Zorlon Cannon, probably others.
Mutable Instruments Edges is a discontinued 4-voice chiptune oscillator.
Soulsby Oscitron runs on an Arduino, but is still 8-bit resolution and very much sounds like it belongs in the chiptune space.
Beast-Tek does a lot of lo-fi VCOs.
Zymos
Post by Zymos » Fri Jan 24, 2020 11:41 am
Pittsburgh Game System, though I can tell you are really talking about audio sources.
lisa
Post by lisa » Fri Jan 24, 2020 11:43 am
Not based on any chip but the Noise Engineering Ataraxic Translatron comes to mind. It is ”a linear feedback shift register oscillator similar to those used in the first generation of home video game consoles such as the Atari VCS as well as many other classic arcade games”.
NARC NOISE
Post by NARC NOISE » Fri Jan 24, 2020 11:46 am
Thank you sir! I have all of those LFSR modules you listed except the EMW, as well as a Rung Divisions (which is seriously fantastic), but I will look into the other synths/modules you listed. I love IME/The Harvestman stuff by the way, that Zorlon Cannon paired up with Tyme Sefari/SOT expander and the Bionic Lester MKIII is complete and utter auditory nonsense (in the good way....) I have the Beast-Tek Dirty Glitch, would like to snag some more modules from them.
NARC NOISE
Post by NARC NOISE » Fri Jan 24, 2020 11:48 am
This one is in line for my next case....they had me at the descriptive quote of something along the lines of "making the fax machine jealous"
DSC
Post by DSC » Fri Jan 24, 2020 12:03 pm
I use it all the time!!!!
Reason: undoing the damage
starthief
Post by starthief » Fri Jan 24, 2020 12:24 pm
EMW Arcade Noise was kind of fun, but you might be better off just sticking with the Zorlon. The main thing I remember about Arcade Noise is higher CV voltage = lower clock rate for some reason.
coolshirtdotjpg
Post by coolshirtdotjpg » Fri Jan 24, 2020 2:17 pm
The Special Stage Systems Oscillographic Block uses a sound generation chip from the sega master system.
New video on Prophet 12 Drone Patches:
cg_funk
Post by cg_funk » Fri Jan 24, 2020 2:36 pm
Another vote for Noise Engineering. The Ataraxic modules sound very 8bit video game.
But also, don't forget the NerdSeq. I mean it's not an oscillator, but it actually LOOKs like a video game, and it's basically the perfect sequencer for making video game music.
bemushroomed
Post by bemushroomed » Fri Jan 24, 2020 2:44 pm
Since it wasn't mentioned, the most well known one is probably APC (atari punk console)..
you can get a long way with a bitreducer to make classic 8-bit sounds i think.. i had my braids in 8-bit mode for a long while, can get very C64'ish when modulated "correctly".
NARC NOISE
Post by NARC NOISE » Fri Jan 24, 2020 3:37 pm
Oh, the NerdSeq is also in my next case, along with the MIDI/Sega controller Expander and the trigger expander, as well as a modern day MIDINES cartdridge (fammimidi or something close to that spelling....), and also an adapter that allows for the use of the sound chip in the Sega Genesis via sequencers.
Also, I really have no intrest in making video game music per se, I just really enjoy the lofi drum and oscillator sounds as a starting point for further wonkiness.
megarat
Post by megarat » Fri Jan 24, 2020 3:40 pm
The one you're referring to (about making the fax machine jealous) is the Ataraxic Iteritas, which is a 10hp digital noise workhorse. It's allegedly an extension of the Ataraxic Translatron, but I found that the AT is better at creating tones that are clearly retro-vid inspired. Specifically, the AT's tone "2" sounds like it's coming straight from an Atari VCS, and tone "C" is a great pitched noise. That said, the AI definitely has its place in this genre, and I have both of them racked in my retro-vid-inspired rig.
Thanks for starting this thread, it's right up my alley. I hadn't heard of the EMW Arcade Noise yet, and it's pretty affordable, so I might give it a whirl.
EDIT: another module in this vein is the VCNO by Hexinverter Électronique.
NARC NOISE
Post by NARC NOISE » Fri Jan 24, 2020 3:43 pm
Yes, the AI is in my next case, I think the AT is discontinued??? (it's a 4hp module if I'm thinking of the right one)....probably could snag a used one somewhere.
megarat
Post by megarat » Fri Jan 24, 2020 4:03 pm
NE is still making the AT (yes, their primordial 4hp module), so you don't need to worry about availability for now.
megarat
Post by megarat » Fri Jan 24, 2020 4:14 pm
While we're on the topic, is anyone here using the Zorlon Cannon Mk2 for chiptune-inspired work? If so, how are you using it?
When I originally researched the ZC2, it didn't seem like a straightforward VCO, per se, but rather resembled an LFSR-based Turing Machine. Any illumination would be appreciated.
SphericalSound
Post by SphericalSound » Fri Jan 24, 2020 7:23 pm
Not a module but a standalone, using the genesis/megadrive chips:
MindMachine
weekend warrior
Post by MindMachine » Sun Jan 26, 2020 12:13 am
I have two of the EMW Arcade Noise modules. The reverse pitch control is... lame, but the module for the money is really incredible. LFO mode is really inspiring too. Trippy module for little dough if you have some space.
In use with my 2HP Freeze module I can get some decent glitchy stuff.
intuitionnyc
Post by intuitionnyc » Sun Jan 26, 2020 12:26 am
I don’t know if Harvestman’s Piston Honda has tech in it deriving from video games, but the name is inspired from Mike Tyson’s Punch Out on NES. :)
target_destroyed
Post by target_destroyed » Sun Jan 26, 2020 9:50 am
Several of his modules have video game inspired names.
"Double Andore" is from Final Fight
"Zorlon Cannon" is from Yar's Revenge
"King Slender" is from Pro Wrestling
"Bionic Lester" is from Skate or Die
Not a module, but Twisted Electrons is coming out with the MegaFM in a few months, which has two Yamaha YM2612/OPN2 chips from the Mega Drive/Genesis and loads of controls. Should be awesome.
https://twisted-electrons.com/product/megafm/
They also have the HapiNES, which, as the name implies, is NES inspired.
https://twisted-electrons.com/product/hapines-l/
BlinkyLights
Post by BlinkyLights » Mon Apr 27, 2020 12:29 am
Some fantastic replies. Thank you all.
mckenic
Post by mckenic » Mon Apr 27, 2020 1:07 am
SN Voice
(still have to put my diy kit together!)
Edit - and not a module but the MegaMidi 5!
