Ensemble Oscillator from Matthias Puech & 4ms Company
prphnc
Re: Ensemble Oscillator from Matthias Puech & 4ms Company
Post by prphnc » Tue May 19, 2020 2:10 pm
mqtthiqs
Post by mqtthiqs » Tue May 19, 2020 3:56 pm
Hi there! Second demo of the EnOsc: A simple medley of sounds. It should give you a idea of the palette of timbres that can be obtained. Like the prevous video, no modulation, no post-processing, direct stereo out from the module at various settings, using only the factory scales.
silkynight
Post by silkynight » Tue May 19, 2020 7:42 pm
wow! that "watery" sound at the end. Brilliant work! can't wait to add this in my rack. :sb: :yay:
bemushroomed
Post by bemushroomed » Tue May 19, 2020 9:28 pm
The new demos has impressed me a lot (wasn't that impressed with the first ones). I really like that it has that Freeze functionality, that will be quite useful and makes it stand out against modules such as E352, i think i will prefer this one over it..
Ordered :party:
synonymist
Post by synonymist » Tue May 19, 2020 10:53 pm
Ordered :party:
Me, too: ordered. :)
SarahB
Post by SarahB » Wed May 20, 2020 3:09 am
It’s great. I love it. So versatile! I find that I prefer the sound when I lower the number of oscillators. With 2-4 oscillators instead of 16 the cross-mod is much cleaner. I only wish it had onboard attenuation for the modulation.
MossGarden
Post by MossGarden » Wed May 20, 2020 7:24 am
Perhaps addressable in a FW update?
bemushroomed
Post by bemushroomed » Wed May 20, 2020 7:32 am
Is this in stereo? Try the various stereo modes if you haven't, i bet that can make a bit of a difference in how clean it sounds.. In mono 16 oscs will most likely sound a bit.. messy.
bemushroomed
Post by bemushroomed » Wed May 20, 2020 10:58 am
hawkfuzz wrote:
Mon Apr 06, 2020 3:23 pm
It's not multi-voiced. It has several oscillators that can be different notes, but is one voice.
With its Freeze functionality you can say it's actually 2 voiced, though the second voice is just frozen (still, this if far better than most other multi-oscillators with just the one voice).
xcc
Post by xcc » Wed May 20, 2020 1:18 pm
Well I cracked and got one on the way. This thing seems to have a ton of possibilities. I'm looking forward to playing with the twist and warp in relation to the harmonics.
silkynight
Post by silkynight » Wed May 20, 2020 8:56 pm
(im)Patiently waiting for that "West coast Canadian shipment"
hawkfuzz
Post by hawkfuzz » Wed May 20, 2020 9:11 pm
Waiting for Control to ship. Very excited.
THUMPR BC SC
mqtthiqs
Post by mqtthiqs » Fri May 22, 2020 4:33 pm
AbundantChoice
Post by AbundantChoice » Fri May 22, 2020 7:57 pm
Cannot wait. Mine shows up Tuesday; I've been looking for something to compliment my E370 for a while. I thought the Odessa was going to be it, but i'm glad I held off and got this instead. I think the learning curve is going to be pretty deep, but even in the short demos so far from the creators, ModBap, Devine, etc, there are some bonkers tones coming out of this thing. I can only imagine what starts happening when you throw some effects on it, filtration, etc.
Hovercraft
Post by Hovercraft » Fri May 22, 2020 9:29 pm
Hadn’t intended to order the Ensemble, but I’m digging everything 4MS is releasing, so with the long weekend- I figured it would be fun to try. Totally blew my expectations out of the water—so expressive and the range of sounds is insane. Industrial noise to super melodic, and this is the easiest to control complex osc I’ve ever played. It doesn’t even need a filter because the control over timbres goes far beyond what most filters can do. The design is everything good about modular.
120 ug of pizza
Post by 120 ug of pizza » Sat May 23, 2020 12:45 am
aaaaaaaaaaaand purchased
SalvorHardin
Post by SalvorHardin » Sun May 24, 2020 11:04 pm
Will be more exciting than Tide 2018 4outputs in audio mod, or quantized Clouds grains. Ordered!
xcc
Post by xcc » Sun May 24, 2020 11:08 pm
Yep!
bemushroomed
Post by bemushroomed » Mon May 25, 2020 10:59 am
First test! i like it, good range of sounds and fun to CV
Cortega
Post by Cortega » Mon May 25, 2020 1:26 pm
aahhrg instant Love 😍...i was sold after the first Drone Video in the thread, but now i think i buy two
AbundantChoice
Post by AbundantChoice » Tue May 26, 2020 3:02 pm
Just got mine in and *ZOINKS* this thing makes some bonkers sounds. You definitely want to go low-n-slow with the FM pot (and the Warp pot). But thing thing can generate some tones. I love the default sort of "massive cathedral organ" sort of thing that comes with moving the Root around, but adding in a bit of FM and Warp while playing with twist can get some nicely abrasive sounds as well; it doesn't have to sound beautiful if you don't want it to.
synonymist
Post by synonymist » Tue May 26, 2020 6:35 pm
...can get some nicely abrasive sounds as well; it doesn't have to sound beautiful if you don't want it to.
Excellent. That's what I was counting on. :)
Congrats on yours. Mine should arrive soon...
AbundantChoice
Post by AbundantChoice » Tue May 26, 2020 9:33 pm
A lot of the previews have featured slow moving sequences and heavy modulation and twiddling of the various knobs, so just for the heck of it I slapped together a "faster sequence with minimal modulation" test in about 45 minutes of farting around. Faster sequence into the Root input, slower sequence into the pitch sequence, and a heavily attenuated triangle lfo into the Cross FM for the small repeating "whoosh." That's basically it. No modulation of anything else, no effects, no nothing.
So yeah, it doesn't remotely show off what the module is capable of (this thing is FUN FUN FUN to knob twiddle and doing something like this really doesn't do it justice at all), but if someone wondered what an example of a faster sequence with minimal modulation might sound like, here you go.
AbundantChoice
Post by AbundantChoice » Wed May 27, 2020 5:16 pm
Ok, quick dumb loop test #2 just to explore the module a bit more. Realllllly simple drum loop and backing line from E370, but they're just there to provide a bit of structure. First few measures has basically no modulation at all, the ENOSC is just rising through a four-note scale using the Pitch In. Then at :15 Zadar provides a big inverted-U envelope to the Root In, (heavily attenuated) Cross FM, and (also heavily attenuated) Twist, while the basic four-note Pitch sequence continues. Again, no effects, no EQ, etc etc
Again, this is all super-dumb and super-basic, but the more sound samples that are out there right now the better. I'll stop posting now and let people who actually know what they're doing take over.
hawkfuzz
Post by hawkfuzz » Wed May 27, 2020 9:55 pm
Loving it a lot and glad to finally have it in my life. Haven't made any scales yet but I'm excited about it.
I've enjoyed putting it through the WAVER using the different stereo spread modes.
THUMPR BC SC
