MakeNoise Mimeophon
cloverandgrape
Re: MakeNoise Mimeophon
Post by cloverandgrape »
Mimmo wrote: Fri Jan 20, 2023 6:34 pm I love "noise" as well but this isn't the good kind. It's like a pitched up frozen Darth Vader's breathing, it has too much character, like an element you could add to a track but now it's on every track you use the module. I love Make Noise, I have many of their modules, but this is a flaw, I don't know if it's hardware related or software but it shouldn't be there.
Mine doesn't do that, but I'd be curious to know how to make it do that? Maybe not all the time, but sounds like a neat noise.
cloverandgrape
DirkB wrote: Tue Mar 14, 2023 5:05 pm noise is part of the story like a lot of analog modules; if you hate it, sell it
Is mimeophon considered analog? Since it's "firmware" based, I assumed that meant digital.
GuyaGuy
Post by GuyaGuy »
cloverandgrape wrote: Wed Mar 15, 2023 6:30 pm
Nope. Digital
cloverandgrape wrote: Wed Mar 15, 2023 6:29 pm
Set the Color to as bright as possible and crank your system's output.
MrV63
Post by MrV63 »
Definitely digital. It was modeled after the DeltaLabs Effectron II 19" rack unit digital flanger/delay from the early 80s (which I actually own along with the original Effectron).
It's talked about here:
lukas412
Post by lukas412 »
I just updated. Made a recording in Ableton before and after same settings the noise floor on mine dropped by 8 db.
Addam
Post by Addam »
Hell yeah, thanks for checking that
starthief
Post by starthief »
lukas412 wrote: Wed Mar 15, 2023 6:59 pm I just updated. Made a recording in Ableton before and after same settings the noise floor on mine dropped by 8 db.
Are you sure your Mimeophon has the same input gain setting as it did after the update?
After the update I repeated the test I posted earlier and I get a very similar noise profile -- the level fluctuates by a few dB but it's the same average. (Which is quiet enough for me not to worry about anyway...)
standingwave
Post by standingwave »
That's not insignificant. Thanks for doing the test. I thought it seemed a bit more tamed.
Cheers.
Mimmo
Post by Mimmo »
Yes I measured a drop of the noise floor as well after the update, around 10db!
Mos Eisley
Post by Mos Eisley »
Didn’t realize there were updates at all for Mimeophon! :party:
I also found increasing Color, above unity added too much noise.
aka elxsound
Holofonze
Post by Holofonze »
Has anyone else installed the newest update and notice the hiss/noise db levels drop when set closer to dry?
optiprime8
Post by optiprime8 »
Holofonze wrote: Sat Mar 18, 2023 4:49 pm Has anyone else installed the newest update and notice the hiss/noise db levels drop when set closer to dry?
With the update the noise seems more uniform for me, it’s now similar dry or wet. However I have to turn up the levels very high before I can hear any noise.
