Advanced Trigger and Gate Sequencer
WMD is proud to announce Metron, their most recent addition to their expansive line of eurorack modules. A trigger and gate sequencer at heart, Metron is posed to be the most advanced, live improv and performance friendly gate sequencer on the market.
Our most ambitious project yet, Metron is slated for release late 2018.
Price: $TBA
Metron is a 16 channel trigger and gate sequencer with loads of intuitive functionality, expansion capabilities, and the tools you need to create longer sequences with tons of variation at your fingertips.
Feature list -
16 Channels of trigger and gate signals
View 4 channels at a time and easily switch views
Single track view lets you zoom in on a single track and see 64 steps at a time
Up to 256 step pattern length
Different pattern lengths per channel
Five instantly recallable and chainable variations
View and edit variations that are not playing for easy cue and non stop performance play
Save patterns to SD memory for easy recall on power cycle
No-stop loading from memory
Easy view memory previews lets yous see a pattern before loading from memory.
SD allows for easy update as well as easy back up / file transfer from unit to unit
FX / Fills for instant / momentary variation
2 assignable inputs for external CV control
Tap in patterns with quantized recording with the buttons or external source
Quick copy / paste / clear functions
Internal clock with Swing
dedicated reset output
Expendable for use with up to 4 units displaying a total of 64 steps at once!
MIDI Preset mode lets you send MIDI messages to other modules on the Doepfer CV bus. (for use with WMD SSM, Malekko Voltage
Block, and more)
Random Pattern Generation
Probability per step and group proability functions
Burst per step for ratchet / roll sounds
Custom Fill Patterns for instant fills
Trigger Mutes
Beat repeat / step looping
Manual gates
Fully skiffable at 20mm deep!
So much more!
Metron is 36 HP and 20 mm deep
More items to be added as soon as possible.
https://wmdevices.com/products/metron
