Befaco Muxlicer
Befaco Muxlicer
@ben_hex demo helped me understand how this module could work in my set-up and it's my next buy.
Any other early users around with thumbs-ups for this?
Hoping that Thonk have some at Brighton Modular Meet next weekend...
Just built one yesterday. Only had a quick patch made up so far. But basically I was using it to trigger a couple pico drums and a radio music. But, due to the gate signal I was getting double triggers on the drums...sounded cool, but I need to figure out the best way to change gate length if i'm triggering modules.
Overall really cool module, and really fun to CV the how many gates are output with gate mode. Still have some learning to do though.
Mine is not receiving external clocks consistently. It works fine with the clock output of the Sampling Modulator, a square wave from Batumi, cycled gates from Rampage, but goes dead when I try to clock from Tempi or Maths EOC gates. I am also reading about 5v at the clock input jack of Muxlicer, which I think is probably where my issue is coming from. Has a schematic for this been released yet? I'd love to know at least a ballpark of where I ought look before I put on my big boy pants and pull the damn panel off...
- ben_hex
Glad to be helpful 1n, I’ll be at the Brighton event. Say hello if we pass by.
Muxslicer, extra chip
Built my Muxslicer last week. Works great. Also got the extra chip, used it thinking maybe they updated the firmware? It'd be nice to know.
Here's a tip- when using it as a sequencer, feed a fixed voltage into the "All In" of 1 or 2 volts and it's easier to tune for notes-- the sliders work as level controls of the "All In" level and the default range is like, 5 octaves making it hard to hit notes, even when you have a quantizer on the output. And a quantizer is pretty handy with it- though I'm often feeding it into a Plonk for bass which has its own quantizer. With a 1V input for example, you'll get exactly a one octave range from slider top to bottom.
Also want to say, I've built a lot of kits in my time (built my first kit in the late 1960s), and this is the third from Befaco- I think they do a pretty good job with the kits, instructions were clear, parts grouped nicely, as kits go, they're as good as any I've seen.
Sync
Sync
- behndy
iiiiiii WANT one of these bad boys. any idea when they'll be back in stock in the states?
One minor tip for the beginner- get yourself a good pair of needle nose pliers. You'll want to use them to bend the resistor leads instead of your fingers. The bends need to be fairly sharp 90-degree and close to the resistor body so that they'll lay flat against the PC board. They use pretty small resistors and the space between the holes is just enough. It likely won't hurt if the resistors don't lay flat against the PC but it's cleaner to get them flat and is quite possible to do consistently using needle nose to do the bends.
Sync
Sync
- Learning to Wiggle
hey! a noob question here trying to grasp my recently acquired Muxlicer.
is it possible to use it in a way that every MUX I/O out would output a CV offset set by its own slider, all at the same time and not only when its step is active? like it's just a box of 8 cv offset sliders. that would be super helpful for controlling my ER-301 and so far i haven't managed to make the muxlicer do it. thanks!
That’s a cool idea, but I don’t think the Muxlicer can do that (at least not with the current firmware/programming).eircom wrote:... is it possible to use it in a way that every MUX I/O out would output a CV offset set by its own slider, all at the same time and not only when its step is active? like it's just a box of 8 cv offset sliders. ...
Sound precedes music | Instruments for Neb2 module
- appliancide
It uses an Atmega328P microcontroller for some stuff, but there are multiplexer chips doing the actual switching, so there is no way for the Muxlicer to be reprogrammed to do what you want.eircom wrote:Thanks, that's what I figured. I wish it could do it, it seems rather easy to implement given its current possibilities. BTW, is there a firmware update path on the Muxlicer?danishchairs wrote:I don’t think the Muxlicer can do that (at least not with the current firmware/programming).
@TheCoug Same here! My MUXLICER, accepts all type of signals, Rampage cycles, lfos, oscs, etc etc EXCEPT TEMPI Clock.TheCoug wrote:Mine is not receiving external clocks consistently. It works fine with the clock output of the Sampling Modulator, a square wave from Batumi, cycled gates from Rampage, but goes dead when I try to clock from Tempi or Maths EOC gates. I am also reading about 5v at the clock input jack of Muxlicer, which I think is probably where my issue is coming from. Has a schematic for this been released yet? I'd love to know at least a ballpark of where I ought look before I put on my big boy pants and pull the damn panel off...
I tried with 10 ms trigger, with half cycle clock, and no succes...
Only succes i have is passing tempi out through attenuator, or a vca, or another active circuit... my question is? Its a level problem? Too much?maybe the tempi sends som DC and the Muxlicer dislike it?
I want to connect one tempi clock out to muxlicer clock in as it should be!
