Piston Honda MKIII dual morphing wavetable oscillator
Leverkusen
Re: Piston Honda MKIII dual morphing wavetable oscillator
Post by Leverkusen » Fri May 01, 2020 6:58 am
I just updated and CV over FM amount is a great feature - though it seems to me as that the PH now has a noticeable slew on the pitch v/oct, wich is a bit of a trade off.
Does anyone still have the 1.6 firmware on their hard drive?
klick
Post by klick » Fri May 01, 2020 7:54 am
attached here.
It's not the original zip which I did not kept, but it's the 1.6 original firmware and readme.
good tests ;)
pistonmk3fwv16.zip
(479.86 KiB) Downloaded 10 times
Leverkusen
Post by Leverkusen » Fri May 01, 2020 8:19 am
Thank you!
After downgrading to 1.6 the v/oct is stable again. So no 1.7 for me right now - what a pity... :sadbanana:
droningspaghettimonster
Post by droningspaghettimonster » Fri May 01, 2020 8:27 am
ouch! thanks for letting us know. I guess I'll wait with 1.7. hopefully Scott will iron this out quickly, since its a fresh firmware.
jwise
Post by jwise » Fri May 01, 2020 3:34 pm
Guys, Scott has been made aware of the slew issue that Leverkusen identified and will be working on it this weekend. There might be a similar issue on Hertz Donut that this helps him with. Thanks are sent to Leverkusen.
Post by droningspaghettimonster » Fri May 01, 2020 3:46 pm
thanks for the report. getting slew-fixes for both vcos sooner than later would be amazing.
Flamusic
Post by Flamusic » Sat May 02, 2020 6:38 am
My Piston Honda know is loading preset 2 on startup ?
Anyone else ?
klick
Post by klick » Sat May 02, 2020 7:16 am
Anyone else ?
yes, it's fully expected.
To change it : press the black encoder + the link button
you'll see the option "startup preset", change it from 2 to "no preset", will do the job ;)
Flamusic
Post by Flamusic » Sat May 02, 2020 11:53 am
Anyone else ?
No matter if i change it to preset 1 or no preset, its loading preset 2 on start up
Leverkusen
Post by Leverkusen » Sat May 02, 2020 12:34 pm
Anyone else ?
Then you have set the preset CV input to CV+offset and the attenuator is set to a small offset. Just turn it full CCW and you start with the preset you have specified in the menu. :tu:
Flamusic
Post by Flamusic » Sun May 03, 2020 4:39 am
Anyone else ?
Thats it :tu:
lordymosh
Post by lordymosh » Wed May 06, 2020 6:44 pm
I'm not sure if there is an issue with my x, y and z wave bank attenuverters.
Say I'm on wave 1 for x, y and z banks. I add a square wave lfo from my batumi to the CV input for x bank and I turn the attenuverter clockwise. I would expect the wave to go between wave bank 1 and 2 but when I turn it up, it starts to go between bank 1 and bank 8. I wouldn't think I'd have to attenuate the lfo signal before going into the x bank CV input as it has a dedicated CV attenuverter?
Is there a problem with my module? Still on firmware 1.1.
uniquepersonno2
Post by uniquepersonno2 » Wed May 06, 2020 7:07 pm
What happens when the attenuverter is closer to the 12 o'clock position?
It's done!
Ever growing, ever changing... I need some longer cables.
autopoiesis
Post by autopoiesis » Wed May 06, 2020 7:16 pm
also, your batumi LFO is bipolar. so when it goes below 0V the honda wraps around back to bank 8 (I believe this is documented behavior). if you want a bipolar LFO to shift the table between 1 & 4, you would want to offset the axis control slider to sit at 3 in addition to using the CV input attenuator.
lordymosh
Post by lordymosh » Thu May 07, 2020 6:02 am
Ah yes that would be the case. I'll try this out later. Thanks for the tip. Looks like I may need another attenuverter module. Currently only have 3xmia.
joskery
Post by joskery » Thu May 07, 2020 6:50 am
You could just set, say, slider X to ~2.5, connect the Batumi LFO to X axis CV in, and set the attenuverter of axis X to a level where you get swinging between values 1 and 4. No additional module needed :guinness:
lordymosh
Post by lordymosh » Fri May 08, 2020 10:45 am
Setting the slider in-between wave values worked a treat. Thanks!
studioutopia
Post by studioutopia » Fri May 08, 2020 11:59 pm
I just uploaded 8 wavetables from the Buchla 259e Twisted Waveform Generator into my Piston Honda MkIII.
Here is a demo of what came out.
modulation from Pamelas NEW! Workout and some additional motion from the human CV generator.
Envelopes from Quadrax driving two channels of the LXd low pass gate for each OSC on the Piston.
I am also manually adding some of the internally routed FM to OSC A.
klick
Post by klick » Sat May 09, 2020 2:42 am
great work !!!!! thanks for sharing
joey
Post by joey » Sat May 09, 2020 2:14 pm
do you mind sharing those wavetables?
Mabuse
Post by Mabuse » Sun May 10, 2020 1:51 pm
+1
messiah_ward
Post by messiah_ward » Sat May 16, 2020 5:40 am
Any news on a fix for the V/octave slew in 1.7?
Post by droningspaghettimonster » Sat May 16, 2020 6:44 am
Hopefully its taking longer because HD slew will also be fixed. :hihi:
pmarchitect
Post by pmarchitect » Sat May 16, 2020 12:53 pm
Mine is arriving tomorrow.
:omg: :woah:
pmarchitect
Post by pmarchitect » Sat May 16, 2020 1:01 pm
Whoops, I started chair dancing and forgot about the wave tables :hihi:
