Piston Honda MKIII dual morphing wavetable oscillator
johannes
Re: Piston Honda MKIII dual morphing wavetable oscillator
Post by johannes » Thu Jul 08, 2021 4:24 am
Looking forward to hear more phmk3 fm stuff here... i can imagine that combined with the preset engine you can do crazy things.
soggybag
Post by soggybag » Thu Jul 08, 2021 9:25 am
tommygee wrote:
Thu Jul 08, 2021 3:27 am
soggybag wrote:
Wed Jul 07, 2021 11:55 pm
autopoiesis wrote:
Wed Jul 07, 2021 5:45 pm
Yeah johannes has it right. Use the input labeled "CV".
That’s it! I knew I had to be doing something wrong. I guess the FM input is only for audio signals so they use the FM CV input to control the FM amount when switch it in the menu. Thanks!
Where, and in what menu, do you switch this ?
Press and hold the rotary encoder and then press the mode button on one of your oscillators. This will show the oscillator menu. Scroll to the bottom the last item is the FM CV options. Press the encoder again to edit this and rotate to change the option. There are two choices there. Press the encoder Gaian to set your choice.
This option is only available with firmware 1.81
tommygee
Post by tommygee » Thu Jul 08, 2021 11:21 am
Ah that's why I could not find it, being on firmware 1.2 Guess its time to get that Picket and update lol
soggybag
Post by soggybag » Thu Jul 08, 2021 1:16 pm
This was such a useful option I had to do the update!
tommygee
Post by tommygee » Mon Jul 19, 2021 4:32 am
I was told that the Pickit3 is no longer available here in Sweden. Does anyone know if this one would work for updating firmware ?
https://www.electrokit.com/produkt/pickit4-debugger/
Did try and write Industrialmusicelectronics, but they haven't answered any of my emails for years. Nice customer support lol
nocontact
Post by nocontact » Mon Jul 19, 2021 8:35 am
Scott can take few minutes up to weeks to answer
https://www.ebay.com/itm/264280036523
Used to be the best deal on pickit3 in EU afaik, purchased in 2019 for 21 eu. 29 is not so bad, shipping only 2. Have upgraded all my mk3 modules without hastle.
James_S
Post by James_S » Mon Jul 19, 2021 9:02 am
I think all the pickits nowadays are clones.
I bought a clone off amazon and it worked just fine for upgrading my Kermit firmware.
Leverkusen
Post by Leverkusen » Mon Jul 19, 2021 4:56 pm
I had no issues with my cheap clone on the MKIII modules. It did not work with older modules though. Luckily I found a used original on ebay, which worked with MKI modules then.
lordymosh
Post by lordymosh » Tue Jul 20, 2021 3:06 am
I got the PH Mk3 July 2018 and was still on firmware V 1. I finally upgraded to 1.81 and I wish I did it sooner! Using the pickit to upgrade put me off but I was able to upgrade first time trying with no issues. I just followed the youtube video for upgrading firmware.
_gasStationShrimp
Post by _gasStationShrimp » Fri Jul 23, 2021 1:48 pm
I've was wondering if anyone here uses Silent Way/CV Tools to send v/o to their PH. I've never really been able to get the tracking right and so finally emailed scott at IME and he got back to me with a mention of the tuning procedure, and an explanation as to why its calibrated from 1v-7v (that there is a dead band around 0v due to reverse voltage protection).
He also mentioned that I can send it for a factory recalibration, but since they are just going to use the same procedure I'm wondering if that will actually fix my issue, or if its not possible with either Silent Way or CV Tools. If one of the two can, I'd imagine its silent way, but I've been using CV tools lately because it requires less tracks/setup. Anyone here using either of those two to sequence their PH MKIII?
martibs
Post by martibs » Thu Aug 05, 2021 7:42 am
Will updating the firmware from 1.5 to latest fix the CV V/oct pitch tracking issue?
Flamusic
Post by Flamusic » Thu Aug 05, 2021 11:34 am
No
Nightly Closures
Post by Nightly Closures » Thu Aug 05, 2021 12:19 pm
I sequence mine from a number of different sources and have never had tracking issues with either OSC. I’m also using a very old firmware. I’d like to update the firmware to utilize the improved fm option, but I might just leave it as I’d hate to mess with anything and have these tuning issues some of you have.
Flamusic
Post by Flamusic » Thu Aug 05, 2021 1:53 pm
I think tts relativ what tuning issues are for some people.
When you play blips and blops ore stay within a few notes its not noticeable for many people i think.
But if you try to play with some other tuned Instruments and look closer at a precise tuner its easy to see and hear.
It was also confirmed by Scott that there is an Issue.
But no fix was offered
studio460
Post by studio460 » Mon Sep 13, 2021 8:20 pm
Anyone here have any clue to their current production schedule? Detroit Modular told me they were getting an IME shipment a couple months ago and I either missed it (quite possible), or it never came. They actually had several IME modules in stock late last year, but I had spent so much money at that point, I couldn't rationalize the purchase. I guess I should've just bit the bullet and bought every IME module they had.
chvad
Post by chvad » Mon Sep 13, 2021 10:39 pm
I just emailed IME last week and they told me they were about to ship out ,doubles to Europe and the. The US shortly afterwards. I’m also waiting to grab a Piston Honda
James_S
Post by James_S » Tue Sep 14, 2021 3:48 am
Hopefully that will include the Bionic Lester as I've had it ordered since March!!
Bascule
Post by Bascule » Thu Sep 16, 2021 2:33 pm
Hi there,
Thomann has Piston Honda MKIII on stock, if anyone is interested. At least in Germany they do . They just sent out mine it seems :eek:
Kdistortnoise
Post by Kdistortnoise » Tue Sep 21, 2021 9:15 am
Just receive my Piston Honda Mk3 from Thomann and the PIN 1 on the back of the module are totally bend. Do i need to sent it back ? is it ok to install the module in my rack and use like it ? Can i fix it carefully with my fingers ? What is this PIN 1 ? Sorry im totally new to modular and im very affraid…
Thank you for your help,
Kevin
Kdistortnoise
Post by Kdistortnoise » Tue Sep 21, 2021 9:17 am
Photo here..
Sleepfc
Post by Sleepfc » Tue Sep 21, 2021 9:42 am
Kevin
It’s fine, you can still use it. Literally every piece of IME gear has this issue, not sure why but they remain fully functional
Leverkusen
Post by Leverkusen » Tue Sep 21, 2021 11:09 am
Kevin
That's the header you connect the PicKit device to to update the firmware. Pin 1 refers to one of the 6 pins and shows the orientation of the header when you connect it. The PicKit has a small triangle on the corrsponding side.
As sad above nearly all IME modules look like that when you get them. You can keep it like that until you need to update or just bend them in place again. Just take care that they are not bend so severly that they are touching each other.
It's an decision they made about how to pack and ships things properly that is not easy to understand.
don_looney
Post by don_looney » Tue Sep 21, 2021 12:19 pm
Hi there,
Mine is also on the way :sb:
I want to use the Massive X wavetables with it. Anybody did this already?
mixxalot
Post by mixxalot » Tue Sep 21, 2021 12:25 pm
I have a question. Since I have the Kermit MK2 and Hertz Donut, is the Piston Honda still worth getting and if so, what would it add to my setup?
My music:
https://soundcloud.com/modben
My modular setup (always work in progress)
Doepfer Monster
https://www.modulargrid.net/e/racks/view/1533298
Sequencer Modular Case
https://www.modulargrid.net/e/racks/view/1533306
MDLR 14u travel case (super heavy but portable):
https://www.modulargrid.net/e/racks/view/1391380
VanEck
Post by VanEck » Tue Sep 21, 2021 2:49 pm
not much overlap at all between the donut and piston. very different oscillators.
kermit shares some similarities in that it can be used as an osc and is wavetable table based... but modulating the piston with the kermit is like peas and carrots. they go together very well and the piston is far more powerful as a voice than the kermit.
also piston can do audio processing, which is incredible.
SysEx Dumpster Podcast - modular, gear, and other garbage
