I found the solution, parameter 1 (clip mode) has to be set to 1 and not 0
Animal Factory Amplification
Expert Sleepers Disting Mk4
- 0-nikkor
Re: Expert Sleepers Disting Mk4
with the cross fader its fading back and forth between the clock sources so you'll get a period were they are being mixed together the switch is the better algo for the job
just a hermit lurking
https://www.modulargrid.net/e/racks/view/814271
https://www.instagram.com/mars.face/
Hello,
I've bought a disting and it came with the 4.7 firmware.
in order to update it to the latest version I have to flash the b2 bootloader and then I can flash the latest firmware, am I correct?
thanks
thanks
Correct.
New album "Rolling Like A Bullet" out now:
https://andrew-ostler.bandcamp.com/albu ... e-a-bullet
Been using the H5 algo (Dual Euclidean Patterns) quite a bit recently, adjusting the parameters via MIDI through an old Korg Nano Kontrol.
That said, I struggle with the rotation parameters.
They basically don't rotate but push the patterns further out and cut/crop the triggers that would go beyond.
Let's say you have 16 step rhythm, rotate 8 steps, this generates 8 steps of silence + the first half of the active pattern.
Is this the intended behaviour?
(I'm on the latest firmware)
It isn't, no. Let me check that.
You're quite right. I can't believe nobody's ever noticed that before. Please try this beta:
https://github.com/expertsleepersltd/is ... .2beta.zip
works like a charm now.
thanks so much for the super speedy trouble shooting oz!
(really liking the repeat feature as well.)
Thanks for confirming.
I have a Disting MK4 and the midi breakout.
Can I connect another MK4 or MK3 to the same midi breakout so both can recieve the same midi clock?
And if so, how?
Thanks.
And if so, how?
Thanks.
You can chain a second MK4 (not sure about 3) directly from the MIDI out of the first, with Dupont cables. But set it to MIDI thru. I have mine setup this way, along with the second MK4 connected to the out of the breakout.
Re:
New module for me disting 4. I can't see a multiplier algorithm? Or do i miss osme info?sixnon wrote: ↑Thu Jun 22, 2017 11:13 pmCan confirm this works with input from phone into X and a voltage into Y. Hadn't even considered that possible, thanks another time Schledge!Shledge wrote:I think the multiplier can do that, although you'll increase the noise floor the same amount as it's done digitally.nedrush wrote:is there an algorithm to convert line level to eurorack level so I can plug my phone or laptop headphone out into my modular? Or is that something for an update?
What is the name of this algorithm?
Algorithm A-2 -- Four quadrant multiplier.
Firmware 4.23 is released.
As a DFAM owner, thank you!
Not sure what you mean. There is no folder. The download is a zip file, containing the firmware.
- soundspossible
- Learning to Wiggle
Great for my mi marbles this.
. Thanks.
. Thanks.
Just double click the zip file to get the bin file. Works for me.
Witch algorithm can I use for a m.i. branches like function?
Believe there is no Bernoulli gate algorithm.
- Muff McMuff
The switch algo might work as it has a probability setting.
