Animal Factory Amplification
Expert Sleepers Disting Mk4
DukeOfPrunes
Re: Expert Sleepers Disting Mk4
Post by DukeOfPrunes »
Thanks os. Anxious to play me some Disting Bongos!
phutureboy
Post by phutureboy »
would it be possible to do what the Doepfer A-183-4 does ? that is to convert the levels of digital control signals (e.g. gate, trigger, clock) to another voltage level (+12V or +5V) ?
FS: EMS AKS | WTB : Syntech E951
os
Post by os »
Yes, absolutely, though the disting's outputs don't go above 10V.
phutureboy
So which algo ? the Attenuverter/offset ?
os
Post by os »
Yes, or the Multiplier.
Spectra
Post by Spectra »
The attenuverter / offset will be handy, thanks.
phutureboy
nice, thanks !
1n
Post by 1n »
I'm setting time aside tomorrow for updating...
...and adding easy access to 16 favourite functions via a 'favourites.txt' file placed in the root of the SD card, and these are accessed as O1-P8, with .txt contents:
disting favourites v2
A1
A7
B3
<etc., in the order you choose>
^today's learning
phutureboy
os wrote: Mon Nov 29, 2021 12:39 pm Yes, or the Multiplier.
With both I get only up to 9V, could it be a problem with my Disting or a limit of the algo itself so that I can't go all the way up to 10V ?
os
Post by os »
There's quite a lot of variation in the actual output maximums of each individual unit. It's nominally 10V but I've seen much less.
phutureboy
So you mean, some other Disting could go to 10V and another only to 8,5V for example ?
os
Post by os »
I would be very surprised if one went lower than 9V.
phutureboy
OK so you mean from a Disting to another I could get any value from 9 to 10V then ?
os
Post by os »
As a maximum, yes. The calibration means that below that maximum you still get the expected voltage.
phutureboy
Not sure which calibration you mean. Would there be a way to calibrate my Disting so that it does supply the 10V ?
os
Post by os »
The factory calibration, and no.
0-nikkor
Post by 0-nikkor »
disting mk4 - Tuner (4.21)
Wow! Now it is really very usable! :yay: :hail:
studiocode
Post by studiocode »
Hi!
I've created a little web tool for the Disting Mk4. You can quickly browse all the available algorithms (firmware 4.21) and view the parameters and descriptions.
If you have a MIDI breakout connected to your Disting and you use a browser which supports the WebMIDI API (Chrome recommended)
you can "pilot" the Disting directly from your browser: load an algorithm, change the parameters.
This little application is available at https://studiocode.dev/disting/
The code is open-source: https://github.com/francoisgeorgy/distinguished
Feedback welcome. If you find a bug or for anything else, please open a ticket in the GitHub project: https://github.com/francoisgeorgy/distinguished/issues
Thank you!
Note 1: to check if your browser supports WebMIDI: https://webmidi.info/
Note 2: for more info about WebMIDI: https://studiocode.dev/resources/webmidi/
os
Post by os »
:guinness:
Naive Teen Idol
Post by Naive Teen Idol »
studiocode wrote: Tue Dec 14, 2021 11:38 am Hi!
Thank you!
This looks awesome. Using Chrome on Big Sur, I've confirmed WebMIDI works on my browser and I get a list of my MIDI devices when I test it -- but am not able to get it the MIDI output pull down to work on your tool.
studiocode
Naive Teen Idol wrote: Tue Dec 14, 2021 2:47 pm
Thank you!
Hi!
Did you try to refresh the page after you connected your device? The list is still empty?
Naive Teen Idol
I got it -- I had done all that, but I also had to enable the little piano keyboard in the browser bar. This is terrific, thanks for building it.
studiocode
Naive Teen Idol wrote: Tue Dec 14, 2021 3:45 pm I got it -- I had done all that, but I also had to enable the little piano keyboard in the browser bar. This is terrific, thanks for building it.
Yes! That's right, the MIDI support must be enable in the browser.
Enjoy your Disting!
waldmusic
Post by waldmusic »
Os, have you considered adding a straightforward clock divider as a mode?
os
Post by os »
The Clock algorithm will do that.
