The Definitive Connecting Power Thread
Peng33
Re: The Definitive Connecting Power Thread
Post by Peng33 » Thu Mar 18, 2021 10:16 am
Thanks. Made a separate thread for this because I was not getting any responses here. Went with the 3000 mA one for $25 less, because with only a few modules with incomplete power stats on Modular Grid, the entire setup in 9U 84HP was less than 1000 mA TOTAL. So the 3000 mA one should be fine.
bsbazzman1
Post by bsbazzman1 » Sat Mar 20, 2021 3:54 pm
Any experience on if the red line is correct on Erica Synth modules?
cinnatoastg
Post by cinnatoastg » Mon May 03, 2021 7:02 am
Hoping someone smarter than I can check my power and see if I'm alright. This is the theoretical power consumption of my finished rack:
1181 mA +12V | 677 mA -12V | 0 mA 5V
I'm powering it with a 4ms Row 35 whos specs are:
+12V @ 1.4A | -12V @ 1.25A | +5V @ 1.0A
I'm getting up there on the +12v rail and was just wondering if this will be a safe long term solution. I can upgrade to the Row 45, but I don't want to unless it's necessary.
Katherine Alicia
Post by Katherine Alicia » Mon May 03, 2021 7:09 am
I`m making my own cables up now, I started with a Known Good cable and copied it, checking it several times over and then giving it to someone else to check (2 sets of eyes are better), and I never make more than a few at a time so there`s no danger of complacency setting in.
Just need to put together a little test rig now, but all the ones I`v made so far are good and I`m using them.
*Peace, Love, Unity, Respect*
https://www.youtube.com/KatherineAlicia
datsmabowl
Post by datsmabowl » Mon May 10, 2021 1:44 pm
Knight's Gallop - any idea which way up?
modeleus
Post by modeleus » Tue May 11, 2021 5:14 am
It should. A trick to know where -12V pin is in a shrouded header is to locate the little tab. -12V should be left from the tab.
As I see in the picture yours is correct.
modeleus
Post by modeleus » Tue May 11, 2021 5:16 am
The only problem that you could have is the power spike needed when powering up all the modules at the same time. Once all the modules are turned on the continuous power should be fine.
modeleus
Post by modeleus » Tue May 11, 2021 5:18 am
-12V label is written down the connector. You should orient the red side of the power cable to that label.
charonme
Post by charonme » Sun May 16, 2021 8:27 am
eewok typoq wrote:
Mon Feb 22, 2021 4:02 pm
doepfer A-100 diy Psu
led's don't light up
you most likely burned out the fuse, just plug in a new one (it's in a little green box, there are even photos of it just a couple of posts above). I had to change the fuse on mine at least twice already
here are the recommended fuse ratings depending on which exactly PSU you have
spotify, bandcamp
Heptaphasis - DIY 3HP 7-phase quadrature sine LFO
DaytimeBender
Post by DaytimeBender » Tue Jun 15, 2021 11:05 am
I have some questions about using these multi connection ribbon cables:https://patchwerks.com/collections/euro ... ower-cable
My case is the Intellijel 7U 104HP Performance case. I've run out of headers to plug modules into, but still have more free HP in my case. I read elsewhere that you can use these multi connection ribbons to plug multiple modules into one socket.
All the modules I'm planning to use have combined power needs well below the total power the case's bus board puts out. So no worries there I think. But are there power restrictions for how much draw you can have on one individual socket? I did not see anything in the performance case's manual that addressed this.
Also, I read that using multi connection ribbons like this can sometimes introduce noise to your signal. Are there certain modules that would be better suited for a multi connector than others? Like should I not put my VCOs on these multi ribbons or other modules that are handling audio rate signal?
My Beeps & Boops: DaytimeBender
biggerovski
Post by biggerovski » Wed Jun 23, 2021 10:47 am
Does anyone have any experience with the Tall Dog skiffs? I believe the power supplies were designed by MIT students! Seems like a few accessories are needed to get up and running, but overall, seems like a decent deal for an expandable rig.
jingo
Post by jingo » Sun Jun 27, 2021 3:37 am
Its perfectly labeled. Can't see whether the header is shrouded, but just be sure that -12V connects to -12V on your cupboard. The red stripe is an indicator but you can't always rely on it.
Best,
jingo
jingo
Its perfectly labeled. Can't see whether the header is shrouded, but just be sure that -12V connects to -12V on your busboard. The red stripe is an indicator but you can't always rely on it.
Best,
jingo
jingo
Post by jingo » Sun Jun 27, 2021 3:39 am
-12V is down on your pic, it's labeled 12V with a white bar to the left.
JedTheFish
Post by JedTheFish » Wed Jul 21, 2021 10:12 pm
Sometimes I just need each configuration in a graphic to remind me what pin does what. I trust cables because I would rather replace a module than do measurements on each one. Every time you get in a car, do you check the headlights and turn signals? Top to bottom, a pair of each: Gate, CV, +12, +5, Gr, Gr, Gr, -12. Right? Anyone not with the program I don’t have time for. Perfect Circuit takes returns and they are ten minutes away.
noisewreck
Post by noisewreck » Thu Jul 22, 2021 12:03 pm
You have +12 and +5 pins reversed in your 16pin diagram. Check out this Noise Engineering post:
https://www.noiseengineering.us/blog/power
JedTheFish
Post by JedTheFish » Sat Jul 24, 2021 4:22 pm
Thank you. Corrected graphic.
plragde
Post by plragde » Mon Jul 26, 2021 7:29 pm
I have just put two together for 6u x 104hp with a 70W power supply (currently populated with only 24hp). It's my first experience with Eurorack, and I have all of a few hours' experience with the Tall Dog, but I'm impressed by the design, the build quality, and the flexibility, so far at least. If you have any questions, I can answer them.
I have a Bastl Ikarie and there's no definitive indication in the manual or on the module how to orient the 10-pin connector. There's a line on the board on one narrow side of the pin block that I'm guessing indicates –12V, but I'm not taking a chance. Hopefully the manufacturer responds to my query soon.
noisewreck
Post by noisewreck » Sat Jul 31, 2021 11:40 am
The line typically indicates -12v. So, as long as your power ribbon is built properly, and you line up the red stripe on -12 on both ends, you should be fine. If you want post a pic and we can double-check.
plragde
Post by plragde » Sat Jul 31, 2021 11:46 am
Thanks – Bastl got back to me and confirmed this. Though, thinking about it now, there's no indication on the Tall Dog case that the red stripe is –12V. There are no instructions except for the photos on Control's product pages.
