Time Machine price question
gnombient
Post by gnombient » Mon Jan 04, 2021 11:53 am
What does a Rev. B go for these days?
mamonu
90s ambient miscreant!!
Re: Time Machine price question
Post by mamonu » Mon Jan 04, 2021 12:49 pm
400$ + ish i think. But dont quote me.
frac & 100m & eurorack (equal opportunities wiggler)
:blacet: :blacet: fracmodular.github.io :blacet: :blacet:
soup
Post by soup » Mon Jan 04, 2021 5:54 pm
I've seen quite a few go for a lot less than that. Maybe $250?
Hermetech Mastering
Post by Hermetech Mastering » Sat Jan 23, 2021 6:12 am
I had three in my system at one stage, best BBD I have ever used.
Flareless
Post by Flareless » Sat Jan 23, 2021 6:22 am
If you're a DIYer then you can get the PCBs from SynthCube for $65USD (at this writing)
As for price I wouldn't expect to be paying $250 considering the MN3005 goes for $50 alone. Perhaps I'm wrong though.
I do know we just did a custom build for a client which cost more than that.
As HM mentions, it is an EXCELLENT delay.
Rich
What can this strange device be? When I touch it, it gives forth a sound - Neil Peart
soup
Post by soup » Sat Jan 23, 2021 3:16 pm
I don’t think synthcube is selling the frac pcb, I assume that is the larger 5u pcb?
Frac stuff isn’t all that popular. Used modules often sell for less than the the kits did. A time machine in other formats, like the bootleg buchla ones, sell for much more.
But yes, wonderful delay. I’ve since converted mine back to frac but originally built a standalone one…
Flareless
Post by Flareless » Sun Jan 24, 2021 6:21 am
The PCB is definitely a monster.
I know what you mean about the popularity of Frac. I got my start with a PAiA system but decided to focus of MU. I even went as far as to convert my Frac modules to MU format.
Rich
synthcube
you will be assimilated
Post by synthcube » Thu Jan 28, 2021 9:33 am
We do have a small number of original Frac size PCBs at the moment and plan to make more in support of the Frac 're-launch' using the MN3005 from Xvive.
kedowe
Post by kedowe » Sat Jan 30, 2021 12:17 am
Hooray re-launch!!
triplizard
Post by triplizard » Wed Feb 24, 2021 5:00 pm
Trying to decide if I'm going to sell my Frack Rack w/five modules and I started playing around with mine last night for the first time in a very long time. It can be a bit finicky but it does sound really nice.
synthcube
Post by synthcube » Wed Feb 24, 2021 5:26 pm
lovely!
werock
Post by werock » Thu Feb 25, 2021 4:35 am
It's a great sounding delay!
emmaker
Post by emmaker » Thu Feb 25, 2021 7:04 pm
I got a bare PCB and kit without the MN3005 from John and built it up using a synthcube original MN3005. Works great and really like it. I did a front panel from Front Panel Express and it wasn't cheap. I did have some issues with mine. Didn't have the ticks/scales for the pots quite right and this was before scales were added to FPE SW. I went back and added them using the current FPE SW rev 6.33 and moved the labels +,-, ENV (EXT) and INT left some. Here's the file for the panel, feel free to use it.
BUT!
I have not had this version made. Print it out 1X and make sure it will work for you before you have it made! Specifically look to see if the tick marks will work with the knobs you are using.
If you want cheaper versions remove the fill for the lettering/graphics or go with a straight aluminum panel (not anodized) and printed (not engraved) lettering. Euro-rack people have done the straight aluminum and printed lettering so examples are out there.
And if someone does make it let us know how it works.
Jay S
TimeMachine-Txt-4-white-new-ticks.pdf
(31 KiB) Downloaded 34 times
TimeMachine-Txt-4-white-new-ticks.fpd
(2.38 KiB) Downloaded 23 times
synthcube
Post by synthcube » Fri Feb 26, 2021 10:32 am
thanks for sharing that!
bf
12 Bit Wiggler
Post by bf » Fri Feb 26, 2021 9:25 pm
I have one behind a MOTM panel I could just never let go when I moved out of 5u in 2011. I keep telling myself I’m going to repanel it in Frac. It’s on the list. How I have lost hours playing with that delay.
Brian2020
Post by Brian2020 » Tue May 18, 2021 10:34 pm
This thread is making me hate that I just let a Buchla format Time Machine slip by without purchasing it. TripLizards posted audio example sounds really freakin good. Going to have to get one of these in one form or another. Not many BBD based delay modules around and being that my first delay was BBD based it’s something I’m very fond of.
Synthnerd
Post by Synthnerd » Thu May 20, 2021 6:14 pm
I pre-ordered a built one (not yet a kit offering) when it was first re-released. Amazing sound. Mine stopped working a few times but would work again after re-powering it. John said he found that a negative voltage on one of the inputs would stop the clock that runs the whole BBD thing, so he sent a diode and instructions to install it to prevent the negative voltage input issue. > It worked.
Synthnerd
Post by Synthnerd » Thu May 20, 2021 6:37 pm
I pre-ordered a built one (not yet a kit offering) when it first appeared on the then new Blacet.com website. Amazing sound. Mine stopped working when patched up a few times, but would work again after re-powering it. John said he found that a negative voltage on one of the inputs would stop the clock that runs the whole BBD thing, so he sent a diode and instructions to install it to prevent the negative voltage input issue. > It worked.
diophantine
Post by diophantine » Thu May 20, 2021 10:24 pm
Yeah, you definitely have an early version of it! The Rev.A and Rev.B boards had that mod included on the PCB. I've actually never seen a "no rev" version in person.
Rev.B included another mod to correct an issue with the input level overloading the module. I've installed that mod on both of my Rev.A units.
Both mods are documented here: http://blacet.com/tech.html
I forget what rev the MOTM boards match up with. I've got two of those that I've needed to build for more years than I'd like to admit! :doh:
synthcube
Post by synthcube » Fri May 21, 2021 6:12 am
MOTM / 5U Time Machines generally use Rev B. John did a 'large format' Rev B for 5U, and a smaller Frac version of the PCB as well.
